16V Compatable? #897463
01/06/11 10:32 AM
01/06/11 10:32 AM
Out West
408strokerdart Offline OP
Out West
Does anyone know if the ARC membrane style switch panel and circuit board realy is compatable with 16v battery systems? I am thinking of going to 16v and just trying to figure out how many items might be affected.
Re: 16V Compatable? [Re: 408strokerdart] #897464
01/06/11 11:15 AM
01/06/11 11:15 AM
Central,Ohio
FASTFISH420 Offline
FASTFISH420  Offline
Central,Ohio
Should be fine..that is one of the best things I ever did..
1969 Barracuda 8 second all/motor small block 2014 Shelby GT500 Mustang Uratchko Racing Engines www.URE-RACING.com
Re: 16V Compatable? [Re: 408strokerdart] #897465
01/06/11 11:15 AM
01/06/11 11:15 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
I don't know about the arc set up but there are 16v batts with a 12v tap, you could run 16v thru the load side of the relays and trip them with 12.
