Pinion bearing shim question #897359
01/06/11 12:47 AM
01/06/11 12:47 AM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
Putting my 3rd member together and I was wondering if there was an average shim pack thickness that goes between the pinion gear and bearing.
I would like to keep from pressing it apart several times...
Thanks in advance
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Pinion bearing shim question [Re: DemonDust] #897360
01/06/11 12:55 AM
01/06/11 12:55 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Get another pinion bearing (even an old one) and hone it till it's a slip fit.
That will allow you check and adjust and only press once it's dead on.
Re: Pinion bearing shim question [Re: WILD BILL] #897361
01/06/11 01:17 AM
01/06/11 01:17 AM
Menomonee Falls
Menomonee Falls
How do you figure what pinion depth you need?
Or I guess I should say where do you start?
SDG Motorsports
Re: Pinion bearing shim question [Re: DemonDust] #897362
01/06/11 01:19 AM
01/06/11 01:19 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
742 case: start with 0.090" shim
489 case: start with 0.035" shim
Re: Pinion bearing shim question [Re: DoctorDiff] #897363
01/06/11 01:23 AM
01/06/11 01:23 AM
Menomonee Falls
Menomonee Falls
Thanks for the shim info.
I'm looking all over this Richmond pinion and no where does it say the pinion depth
SDG Motorsports
Re: Pinion bearing shim question [Re: DemonDust] #897364
01/06/11 01:28 AM
01/06/11 01:28 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I always used the old shims frim the gears I was replacing as a strating point and adjusted from there.
As far as depth, I used marking compound and ajduted till I got a good contact pattern.
Re: Pinion bearing shim question [Re: DemonDust] #897365
01/06/11 03:31 AM
01/06/11 03:31 AM
It should be mark on the back of the pinion on the flat spot closest to the ring gear center It should have a pinion depth etched on the flat area like 3.335. Not a actual number, just a # for illustratin purposes sometimes they're hard to see, twist it around under a bright light
Re: Pinion bearing shim question [Re: DemonDust] #897366
01/06/11 03:52 AM
01/06/11 03:52 AM
mogadore ohio 44260
racingblues1426 Offline
mogadore ohio 44260
Unless you want to have a howling success i'd seriously consider paying a professional to set up your rear gears. The gears will be shot after only a couple of miles if the correct depth and backlash aren't first set. Don't ask how i found this out years ago.
Re: Pinion bearing shim question [Re: racingblues1426] #897367
01/06/11 05:00 AM
01/06/11 05:00 AM
Menomonee Falls
Menomonee Falls
Cab, I found the number. It was very lightly engraved. With the shims I have I got the pinion depth set 2.765 supposed to be 2.763...
The original shim was .090 have .080 in now so I'm on the track
SDG Motorsports
Re: Pinion bearing shim question [Re: DemonDust] #897368
01/06/11 02:32 PM
01/06/11 02:32 PM
deeper is better(pinion gear head closer to the center of the ring gear center) than shallower, if you don't believe me ask your favorite
