HP manifolds 383-440 interchange list/part numbers?
#897092
01/05/11 08:05 PM
01/05/11 08:05 PM
Posts: 1,220 toronto canada
69chargeryeehaa
toronto canada
Hey guys, i remember seeing a list somewhere about exhaust manifolds that interchange... i found a set with the following part #'s and wondering if they will fit a 69 b-body (charger) 2951865-2 2(8 or 6)98678 also are 383 and 440 manifolds the same/interchangeable? thanks!!
Re: HP manifolds 383-440 interchange list/part numbers?
[Re: JohnRR]
#897094
01/05/11 08:32 PM
01/05/11 08:32 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
yes manifolds between a 383 and a 440 are the same EXCEPT for the 69 A body 440 only left side manifold.
and all c-bodies drivers side is unique.
[Re: bboogieart]
#897095
01/05/11 08:44 PM
01/05/11 08:44 PM
Posts: 75,095 A Banana Republic near you.
JohnRR
He asked if 383 and 440 manifolds are interchangable , which they are between a single body platform .... except in the case of the big block A body which has a unique left manifold for 383 and 440 .
[Re: 69chargeryeehaa]
#897097
01/05/11 09:32 PM
01/05/11 09:32 PM
Posts: 3,407 S.E. Florida, USA
rrunner
S.E. Florida, USA
thanks!!
The left manifold (2951865) is a 70, the right is no # I know of. A 70 right side manifold would be 2899879. If they are both 70 manifolds they will fit fine, but if you order pipes you will need to order them for a 1970 as the R manifold flange is located differently than a 69's.
[Re: rrunner]
#897098
01/06/11 03:00 PM
01/06/11 03:00 PM
69chargeryeehaa
toronto canada
well then i guess they won't fit my 69 charger with correct TTI system.. it was hard to read the #'s off the manifolds, the left is definite.. both were said to come off a 71 cuda 383 so the application seems right with the numbers... but i guess these won't fit a 69 b body
[Re: JohnRR]
#897100
01/06/11 06:04 PM
01/06/11 06:04 PM
69chargeryeehaa
toronto canada
have you already bought the system from TTi ? If not tell them the manifolds you have and they will set the headpipe flange accordingly , it's only the right side that is of concern ... OR I have a pair of 68-69 manifolds for sale .
edit , look at that right one again closely , 2899879 is the mate to the 2951865 .
No i have the HP mani's on my car now with a tti system, but i know someone selling some hp manifolds (the #'s in question) and i wanted them for a spare...cause they're cheep!!!
i'll check the #'s later today.
Thanks for all you guys help!!
