Page 7 of 13 1 2 5 6 7 8 9 12 13
Re: My 1973 Cuda Lemontwist [Re: burdar] #896893
06/08/11 09:18 AM
06/08/11 09:18 AM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Thanks Darren. Being on the rubber does make it seem like I'm getting a little closer. I have a set of 14" magnums that I got for a steal. $80 for a set of 4 they are 6"or 6.5 wide so I may try and get a set of 235/or 245 to go on them not sure what kind of tires though.
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: My 1973 Cuda Lemontwist [Re: 19cuda73] #896894
06/08/11 09:47 AM
06/08/11 09:47 AM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Trying to set the front end up the best I can for the alignment shop. Seems to roll nicely and the wheels measure out equal across the front and back side of the tire. I Just used a square on the concrete floor to check the top and bottom of the rim.
1972 Corvette
Re: My 1973 Cuda Lemontwist [Re: 19cuda73] #896895
06/08/11 09:49 AM
06/08/11 09:49 AM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Front alignment view
1972 Corvette
Re: My 1973 Cuda Lemontwist [Re: 19cuda73] #896896
06/09/11 07:08 PM
06/09/11 07:08 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Don't get too carried away with the alignment right now. Once the grill and bumper are on, your alignment specs are going to change.
You can try to get it fairy close right before it goes to the alignment shop. Also, don't tighten down any of the suspension parts until the full weight of the car is on the suspension.
Re: My 1973 Cuda Lemontwist [Re: burdar] #896897
06/10/11 12:02 AM
06/10/11 12:02 AM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Thanks Darren will hit the alignment shop first thing when it hits the road. thats a ways out! Right now it rolls nicely in the garage with very little effort. Working on the engine compartment and wiring. Dennis
1972 Corvette
Re: My 1973 Cuda Lemontwist [Re: 19cuda73] #896898
07/06/11 09:29 PM
07/06/11 09:29 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Got my upper and lower hoses yesterday for the Radiator install. Thanks Bill Rolik these are nice pieces and will look even nicer installed.
1972 Corvette
Re: My 1973 Cuda Lemontwist [Re: 19cuda73] #896899
07/06/11 09:34 PM
07/06/11 09:34 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
My exhaust also recently arrived and is ready to install. looks like these will go in tomorrow.
1972 Corvette
Re: My 1973 Cuda Lemontwist [Re: 19cuda73] #896900
07/06/11 09:40 PM
07/06/11 09:40 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
My next step will be the grill and headlight bezels. I was wondering if anyone sells a fastener installation kit for this. I checked R/T specialties nothing on line for a 72-74 may just need to call them in the morning.
1972 Corvette
Re: My 1973 Cuda Lemontwist [Re: 19cuda73] #896901
07/14/11 12:30 AM
07/14/11 12:30 AM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
I have been doing exhaust for the last day or so. This is definatly a good time to have a lift in your garage. I wish I did. The accurate system is really nice. The passenger side is going in well it lines up nicely. Had to drill the holes in the trunk pan for the rear exhaust holder. Tips are critical to align in the cutout and I think they look good. Anyone have any specs on how much they protude from the rear valance?
1972 Corvette
Re: My 1973 Cuda Lemontwist [Re: 19cuda73] #896902
07/14/11 12:33 AM
07/14/11 12:33 AM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Heres a picture of the exhaust tip protusion throught the cutouts.
1972 Corvette
Re: My 1973 Cuda Lemontwist [Re: 19cuda73] #896903
07/14/11 12:38 AM
07/14/11 12:38 AM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
The rear valance was the original one to the car and I had a question about the fact that it will vibrate on the bottom of the gas tank and it seems I am missing a stiffener that goes from the lower bumper rail down to the bottom of the valance just inboard of the cutouts. Does anyone have a shot of what these look like on a 73 Here is a picture of a 70 car and this view came from my 73 shop manual but you look up parts and 70 is a unique installation.
1972 Corvette
Re: My 1973 Cuda Lemontwist [Re: 19cuda73] #896904
07/14/11 12:46 AM
07/14/11 12:46 AM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
I think they call it a stone deflector support. The holes are there and any insights would be appreciated..
1972 Corvette
Re: My 1973 Cuda Lemontwist [Re: 19cuda73] #896905
07/14/11 12:53 AM
07/14/11 12:53 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The Challenger rear valances attach different so I won't be of any help there.
The outlet pipe on the Challenger mufflers had a lip where the pipe was expanded so the tip could be installed. That lip located the tip in the proper location so there was no guess work on the assembly line. The Cuda mufflers maybe the same ones used on the Challengers. I would think that the Cuda tips would be self aligning as well.
Re: My 1973 Cuda Lemontwist [Re: 19cuda73] #896906
07/17/11 08:42 PM
07/17/11 08:42 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Finally, here are the pics. As I mentioned, mine is not cutout. There is no center support. There is about an inch of clearance around the gas tank so there should be no rattle. This is an OEM panel I stripped and smoothed out. The body guys then fixed what I did and mounted it for me.
Craig
Re: My 1973 Cuda Lemontwist [Re: denfireguy] #896907
07/17/11 08:43 PM
07/17/11 08:43 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
tank and gravel panel/valnece
Re: My 1973 Cuda Lemontwist [Re: denfireguy] #896908
07/17/11 09:14 PM
07/17/11 09:14 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Craig
Thanks Craig for the pictures. From what Im finding out the only year that used the bottom holes in the valance was 1970. The bracket was very unique and tied into the rear support then into the bottom valance holes on each side of the gas tank.. Thought they should have changed the design and eliminated the holes in the valance once the brkts were no longer used
1972 Corvette
Re: My 1973 Cuda Lemontwist [Re: 19cuda73] #896909
07/26/11 11:57 PM
07/26/11 11:57 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Exhaust completed may need some minor tweaking
1972 Corvette
Re: My 1973 Cuda Lemontwist [Re: 19cuda73] #896910
07/26/11 11:59 PM
07/26/11 11:59 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
A view of the tips
1972 Corvette
Re: My 1973 Cuda Lemontwist [Re: 19cuda73] #896911
07/27/11 12:01 AM
07/27/11 12:01 AM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Pretty well centered and even. The accurate system went together pretty well with only minor adjustments
1972 Corvette
Re: My 1973 Cuda Lemontwist [Re: 19cuda73] #896912
07/27/11 12:13 AM
07/27/11 12:13 AM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Starting to work on installing the Grille tonight The new one fits OK but will need some finessing to resolve some fitment issues.
1972 Corvette
