Re: 1969 Coronet, Super Bee chute mount ????
[Re: RockChip]
#896528
01/06/11 10:49 AM
01/06/11 10:49 AM
Posts: 1,145 Arizona, USA
gsmopar
Arizona, USA
Am I the only guy left racing a 69 B body?
I can post pics of my 69 charger if it will help.
[Re: gsmopar]
#896529
01/06/11 11:03 AM
01/06/11 11:03 AM
Posts: 2,177 ill
dennismopar73
ill
check out the n h r a rules for para mounting rules that apply now i do not run fast enough to have a rag behind me ![](/ubbthreads/images/graemlins/wave.gif)
[Re: dennismopar73]
#896530
01/06/11 05:58 PM
01/06/11 05:58 PM
Posts: 2,586 Illinois, Indiana, Louisiana
ProStDodge
My plan is to have a 2" square receiver mounted behind the license plate so I can use a removable chute mount. Unfortunately, my project is not yet that far along, so I don't have pics of the mount system.
By using standard trailer hitch parts, I can remove the chute with a pin and install a trailer hitch ball for when I need to run the Drag Week event and pull a small support trailer.
Now if I can only finish the car while the Drag Week events still exist.
Scott
[Re: RockChip]
#896537
01/07/11 11:18 AM
01/07/11 11:18 AM
gsmopar
Arizona, USA
YES YES !!!!!! ![](/ubbthreads/images/graemlins/thumbs.gif)
I like I like !!!!!! ![](/ubbthreads/images/graemlins/beer.gif)
Did you just run a bar across the frame rails in the back to mount your tube?
Cross bar and supports. It's a CE kit that I made detachable. There was some debate on this board weather or not a detachable mount is legal. I'm not fast enough for the chute yet, but if needed I can weld everything together. If it's any consolation; the bolt I'm using to attach the mount is larger than the one that is used to tether the chute. ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: gsmopar]
#896538
01/07/11 11:33 AM
01/07/11 11:33 AM
Posts: 10,049 MN
JERICOGTX
MN
Sorry no pics of the inside. Not finished yet, but yes it will tie into the rear framerails, under the floor pan.
Jeff
69 GTX
68 Road Runner
