cast 340 damper versus cast 360 damper Same? #89635
07/16/08 10:02 PM
07/16/08 10:02 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
Is there any difference between a cast 340 damper versus cast 360 damper
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: cast 340 damper versus cast 360 damper Same? [Re: Kam*Kuda] #89636
07/16/08 10:18 PM
07/16/08 10:18 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Not the same. The 340 damper says Cast crankshaft 340 only.
Re: cast 340 damper versus cast 360 damper Same? [Re: Kam*Kuda] #89637
07/16/08 10:28 PM
07/16/08 10:28 PM
Madera, CA.
MowP4rsn Offline
MowP4rsn  Offline
Madera, CA.
They would not be the same due to the 360 having a longer stroke on its crank journals than the 340, requiring different balancing, and the 360 has always been an external balance engine, while I believe the 340 was internal balance, like the 318 for most of its production.
Re: cast 340 damper versus cast 360 damper Same? [Re: MoparforLife] #89638
07/16/08 10:44 PM
07/16/08 10:44 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
cast crank 340 requires 340 cast crank balancer as noted above
Tony
70 AARCuda Vitamin C
Re: cast 340 damper versus cast 360 damper Same? [Re: 70AARcuda] #89639
07/17/08 07:49 AM
07/17/08 07:49 AM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
Thank you, thats what I thought. Having a little debate with a mopar friend.
1654.5 Mustang
1955 Land Rover
Re: cast 340 damper versus cast 360 damper Same? [Re: Kam*Kuda] #89640
07/17/08 02:01 PM
07/17/08 02:01 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
While looking for one this might help you http://www.moparts.org/Tech/Archive/smallblock/5.html
Re: cast 340 damper versus cast 360 damper Same? [Re: UCUDANT] #89641
07/17/08 02:46 PM
07/17/08 02:46 PM
dogdays Offline
dogdays  Offline
The reason is that the 360 balance weight is about 3 times the 340 cast crank balance weight, not even close.
R.
Re: cast 340 damper versus cast 360 damper Same? [Re: dogdays] #89642
07/17/08 03:10 PM
07/17/08 03:10 PM
Upper Midwest
Upper Midwest
R.
Are you sure that it isn't the other way around. The 340 shaft is lighter, swinging the same rod as a 360, and heavier piston than the 360.
