How 2 remove axle thrust pins/spacers from clutch SG?
#896191
01/04/11 07:38 PM
01/04/11 07:38 PM
Posts: 799 Missouri
bb74swngr
mopar addict
mopar addict
Missouri
Hi again all! I assume I will have to take the SG apart to remove the thrust pins...but how is it secured in the pinion carrier? I checked the Tech Archive pictures but it is not that detailed. My understanding is that the pins need to be removed when going to green bearings with no adjusters. Does this all sound logical? Russ...
BigBlock 74 Swinger
Re: How 2 remove axle thrust pins/spacers from clutch SG?
[Re: bb74swngr]
#896192
01/04/11 07:53 PM
01/04/11 07:53 PM
Posts: 25,899 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The originals are held together by a roll pin and can be removed by punching out the roll pin with a small pin punch. (the roll pin is usually broken and the buttons will just fall out)
Newer replacements are held together with a rivet and the unit needs to be disassembled to remove them.
[Re: Mopar_Country]
#896194
01/04/11 08:03 PM
01/04/11 08:03 PM
Posts: 799 Missouri
bb74swngr
mopar addict
mopar addict
Missouri
Thank you so much John and Bruce! OMGoodness, I checked and I can see the roll pin!!!! I will try to drive it out with it all together. Thanks again guys you are the best:) Russ...
BigBlock 74 Swinger
