Correct Rallye Wheel??
#896183
01/04/11 07:38 PM
01/04/11 07:38 PM
Posts: 21 NY
dodgeman3440
NY
I have a 1971 Dodge Demon Sizzler. For those of you who dont know what a Sizzler was is was a package that Dodge did on the 71 Demons only and it had a cosmetic package that took special options and the amenities of a 340 Demon and put them on a standard Demon. My car came with Rallye wheels however when i purchased the car to restore it the original wheels were long gone. What would be the correct Rallyes that i would need for my car? Should i look for NOS/Used originals or just look to getting reproductions? If i go reproductions which is the best company/catalog to use?
1968 Plymouth GTX 440/4 Spd
1971 Dodge Demon Sizzlr
1990 Dodge Power Ram W250
Re: Correct Rallye Wheel??
[Re: dodgeman3440]
#896184
01/04/11 08:15 PM
01/04/11 08:15 PM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
Id go with used originals. they aren't that hard to find. NOS are going to be way expensive and reproductions have to be repainted to be correct anyway, and personally, Id try to use good originals over a repop anyday. should also mention that they reproduce the sbp centers too. keep in mind that the demon sizzlers didn't have trim rings. that should help save a buck. hope this helps
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
[Re: mopars_1]
#896187
01/05/11 04:27 PM
01/05/11 04:27 PM
Posts: 21 NY
dodgeman3440
NY
Thank you very much for your replies, what is the best aftermarket/reproduction parts manufacturers to chose from to purchase wheels? Yearone? etc.....Who is the best supplier?
[Re: dodgeman3440]
#896188
01/05/11 04:41 PM
01/05/11 04:41 PM
Posts: 11,855 Georgetown Ontario Canada
anlauto
Stay away from parts suppliers and go directly to the wheel manufactures....I'm not certain who makes 14" ones because originals are so easy (cheap) to find. Place a want ad here and you'll probably get ten sets in a month. I would get the center caps from PG Classics
CHECK OUT MY NEW WEB SITE !
[Re: sleepyhead416]
#896190
01/05/11 04:52 PM
01/05/11 04:52 PM
Posts: 21 NY
dodgeman3440
NY
Who are the direct wheel manufacturers
