AMD bumper vs. OEM
#895885
01/04/11 08:47 AM
01/04/11 08:47 AM
Posts: 247 I DA HOE
3406pac
I DA HOE
Are the AMD bumpers of show quality? Or should I buy cores and have them refinished? Also any recommendations on a good plating and trim recondition shop in the northwest? Thanks
AAR cuda
71 rag challenger
Re: AMD bumper vs. OEM
[Re: MLR426]
#895887
01/04/11 10:43 AM
01/04/11 10:43 AM
Posts: 21,442 It's a dry heat
gtx6970
It's a dry heat
AMD bumpers are far from show quality, driver quality only. If you want show quality you need to find good original cores and have them plated by a good plater.
logan426
I haven't seen a repop bumper yet I would be happy with
[Re: MLR426]
#895889
01/04/11 04:47 PM
01/04/11 04:47 PM
Posts: 965 Odessa, Fl
blowndart
Odessa, Fl
logan426
I look at the AMDs real close at a Mopar show and decided to go with re-chromed originals. Unfortunately that's the only way to go to get show quality chrome. The AMDs did not have a smooth contour to the base metal on the curves. At least the on the ones I looked at.
[Re: blowndart]
#895890
01/04/11 04:55 PM
01/04/11 04:55 PM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
The AMD ones are not the greatest finished bumpers for sure. But when your local area platers tell you it's 750 bucks minimum PER bumper to replate them , then the 700 bucks for a new pair from AMD sure sounds good. That's what I did, and the AMD's look OK as long as you don't get up too close. As far as fit, no problems.
[Re: 3406pac]
#895893
01/05/11 02:12 AM
01/05/11 02:12 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Although you didn't specify what Body?,....the AMD E bodies were horrible, but have been retooled for the 3rd time....the AMD Charger rear bumper I bought was actually very nice, fit like original, the chrome while not triple plate, was better than factory finish,....came with bumperettes total shipped was $325,...a triple plate of my original was quoted at $900,....it's been on the car for 6 yrs now, no rust,peeling,pits, etc....and the car dose get driven, rain or shine
Mike
[Re: Kern Dog]
#895896
01/05/11 08:06 AM
01/05/11 08:06 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Waddaya mean, NOT triple plated? Triple plated is one of those terms tossed about but rarely understood. I havent heard of a chrome process that ISNT triple. Step one is a copper plate, much like bondo over sheet metal, to fill in any low spots. Step two is the nickel plate, which gives the bumper its color, like paint. Step three is the actual chrome plating, which similar to clearcoat.
I'm more than familiar with the Chromium process, the AMD bumpers that I received has supplied information that the Chromium process used was just nickel and chromium, basically very much like "production chrome" used "back in the day"....hence no "triple chrome"
[Re: DAYCLONA]
#895897
01/05/11 09:14 AM
01/05/11 09:14 AM
Posts: 247 I DA HOE
3406pac
I DA HOE
Was quoted $275 for rechoming from a company in CA. Triple plated and "cured" on the back. What ever that is. Thebumperdepot on ebag Now I just have to find a fair price on a used set. Is $50 fair? Probably less than the shipping.
AAR cuda
71 rag challenger
