driving car with vacuum disconnected from dizzy
#895432
01/03/11 12:49 PM
01/03/11 12:49 PM
Posts: 3,344 Central TX
roe
Central TX
can you damage anything by driving like this for extended periods of time? say highway speeds for 10hrs?
car drove fine during the trip and when i pulled into my driveway it started sputtering and died. now it won't stay running in gear unless I 2 foot drive to keep it from dying . I think it may be vacuum related as my power brakes are firmer than normal. kinda like when a booster is going bad. could i have blown some kind of seal inside my booster, and if so would it cause these symptoms? I also have a pretty decent exhaust leak that needs to be sealed where the manifold meets the exhaust pipes.
I'll double check my vacuum lines later today
thanks roe
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
Re: driving car with vacuum disconnected from dizzy
[Re: RapidRobert]
#895437
01/03/11 10:31 PM
01/03/11 10:31 PM
roe
Central TX
well guys, I sprayed the WD-40 around the intake manifold and didnt get any kind of responce for the motor. I went around the entire intake mating surface about 3 times and still nothing. Its dark now so Im going to clean that oil pooling up tomorrow and see if I can pinpoint where its leaking from. I also sprayed all around the carb mating surface with no luck. I'll try plugging the vacuum line to the booster tomorrow as well, and inspect and trace every vacuum line. It definately seems like a vacuum leak though. I even pulled the hose off the manifold to purposely make a vacuum leak and the response was the same as what Ive been seeing, only worse because it was a larger vac leak, instead of just a small one.
One interseting thing I noticed today however was that it seems worse when the car is cold. As it warms up it gets better. I thought that would be the other way around.
My ehauast leak is pretty bad, on both sides. I used the 360 manifold which have bigger connections to the exhaust pipe. So to make it work I cut the 318 pipe flanges off, and used exhaust clamps and adapters to connect everything temporarily up for the drive here. It wasn't before, but its leaking pretty bad at the adapters now. Could this play a role?
[Re: roe]
#895440
01/04/11 09:13 AM
01/04/11 09:13 AM
Posts: 70 very Southern Indiana
skullbucket
I would say you set the timing with the dist vacuum hooked to full vacuum. Leave the vacuum line unhooked and plug the port on the carb and set your timing to 15 degrees at idle with a timing gun and it should run fine and set your carb idle to where you want. I never use vacuum to the dist and I have total advance of 38 at 2500RPMS.
[Re: mickm]
#895443
01/04/11 05:54 PM
01/04/11 05:54 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
what do you mean by disconnected? if the hose was not connected to the vacuum advance, then you were sucking air into that hose and into the carb, basically a vacuum leak.
Already addressed above but yes the hoe to the carb must be lugged but the one to the distributor makes no difference. Maybe repeating is what needs to be done.
