Re: how hot is too hot of an operating temp?
[Re: 62maxwgn]
#894215
01/11/11 12:44 PM
01/11/11 12:44 PM
Posts: 5,278 San Jose, California
DennisH
Vacation
Vacation
If "some" of you guys would quit trying ti fix things that aren't broke,you wouldn't have so many problems.When they rolled off the asembly line they worked well with the original components.Now everyone has to have aluminun radiators,electric fans,high flow thermostats, aftermarker water pumps and housings.WHY?
Good question.
[Re: 62maxwgn]
#894216
01/11/11 05:04 PM
01/11/11 05:04 PM
Posts: 10,205 Someplace you aren't
SomeCarGuy
If "some" of you guys would quit trying to fix things that aren't broke,you wouldn't have so many problems.When they rolled off the assembly line they worked well with the original components.Now everyone has to have aluminun radiators,electric fans,high flow thermostats, aftermarket water pumps and housings.WHY?
Uh, they didn't come with bored out blocks, higher CR, etc either. Gas was better and so on. No EFI or electric fuel pump, only a few had return lines and those that did didn't run all the way to the carb. Running one on the hot side causes issues. Do what you want.
[Re: SomeCarGuy]
#894217
01/11/11 05:21 PM
01/11/11 05:21 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Well, this one is .030 over,10.6cr,factory 3 core 22" radiator,fixed fan,factory shroud,factory 6 blade A/C water pump,added factory A/C and it doesn't run above 195*.
[Re: 62maxwgn]
#894218
01/11/11 05:28 PM
01/11/11 05:28 PM
Posts: 30,424 Florida STAYcation
dOrk !
The village idiot's idiot
Florida STAYcation
....BECAUSE alum rads are NOT AS GOOD as a brass/copper one ... from what I Have been told.
[Re: 62maxwgn]
#894219
01/11/11 05:46 PM
01/11/11 05:46 PM
SomeCarGuy
Good for you. Not every combo works the same. Not everybody wants a cast iron WP or housing. Not everybody wants an engine driven fan.
My car runs 190-200, even when idling for a long time, has no shroud either. I have aftermarket aluminum pump and housing. Works for me.
The biggest difference I have seen is switching to a bigger radiator, even leaving the opening untouched. Capacity always helps from my experience.
[Re: SomeCarGuy]
#894220
01/11/11 07:32 PM
01/11/11 07:32 PM
Posts: 3,344 Central TX
roe
Central TX
wow, I had no idea there was such a dispute on operating temp. I only asked because myfactory guage was inoperative and all i had was an aftermarket guage and wanted to know where the temp reading was putting me in relation to tue stock guage.
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
[Re: 62maxwgn]
#894221
01/18/11 06:15 PM
01/18/11 06:15 PM
Posts: 3,445 N.Wilkesboro,NC
DusterKrazy
N.Wilkesboro,NC
I bet you still like points ignition to???
[Re: DusterKrazy]
#894222
01/18/11 06:47 PM
01/18/11 06:47 PM
Posts: 15,487 Florida
scratchnfotraction
why yes i do...whats wrong with points?
ok I am a pertronix kinda guy also so i dont run points very long in them,just till i get a conversion put in
and if its not puking the rad shop guru said it not over heating,may be running warm due to poor circulation but its not over heating...
you woulld be surprized at what a new rad will do for a 30+ yr old car some times
roe,i think your gauge would be about 1/2+ way at that temp on the mech gauge
[Re: scratchnfotraction]
#894223
01/19/11 12:00 AM
01/19/11 12:00 AM
DusterKrazy
N.Wilkesboro,NC
I use points distrubutors to but only the housing
Better fuel economy, quicker starting and longer plug life. I changed my '71 Duster over and I could not believe how much more enjoyable it was.
