Re: mag 5.9 sensor questions and what is this? [Re: mopowered] #89408
07/17/08 04:37 PM
07/17/08 04:37 PM
Andrewh Offline OP
Andrewh  Offline OP
Problem is I am using the stock barrel intake. There are no extra holes as far as I can see.
The hole it is sitting in now is actually for the heater hose.
It would bolt in there, but then I would not have a heater.
I have asked if it makes sense for a plug and play controler to require you to drill and tap your intake, but the guy in charge was pretty adament about doing it that way after I pointed out there would be no flow at that hose if I didn't have my heater turned on.
Basically he needs an accurate temp for warm up and start up runs, and so he can cut it back lean when the engine heats up.
My guess is they are shooting for performance and fuel economy in the same package.
Re: mag 5.9 sensor questions and what is this? [Re: Andrewh] #89409
07/17/08 06:08 PM
07/17/08 06:08 PM
Cali S.B
Sub95 Offline
super gas
Sub95  Offline
super gas
Cali S.B
Just sticking it in a closed system will take awhile for it to get to temp, and it would take awhile to go from hot to cold. Not a very real reading.
Re: mag 5.9 sensor questions and what is this? [Re: Sub95] #89410
07/17/08 10:49 PM
07/17/08 10:49 PM
Andrewh Offline OP
Andrewh  Offline OP
interesting. your picture shows the stock wts in a blank on my intake. It has a raised pad there, so I will drill to put the new one there.
The stock one is on the other side of the heater hose tap away from the thermostat housing.
Re: mag 5.9 sensor questions and what is this? [Re: Andrewh] #89411
07/18/08 11:15 AM
07/18/08 11:15 AM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
Well, I figured out where I screwed up on my ASSumption that the Chrysler CTS was the same as the GM parts. I ASSumed that they reacted the same, since the MAP and TPS generally do (as long as you make sure the wiring outputs are correct). In fact, the Chrysler CTS relies on some code in the PCM and some switched resistors to give the PCM the coolant temp info it needs. Basically, the PCM uses one resistor set to get very accurate temp data up to about 125*F, then switches to another resistor set to get very accurate temp data above 125*F. I found this information here:
http://www.kemparts.com/TechTalk/tt14.asp
So, my bad on making what amounted to a wild-a$$ed guess that Chrysler would do something as simply as GM did...
I still think they COULD set up the temp/ohm table to reflect the Chrysler sensor values, since Megasquirt can handle that pretty easily. My other question is, what other CTS units are out there that provide the response curve Painless wants, but fit the Chrysler location? Adding a $20 sensor to their kit would be a nice solution compared to drilling/tapping the manifold or cobbling together a squirrelly-looking stand pipe.
Sorry for the confusion, but at least I learned something...
Clair
Re: mag 5.9 sensor questions and what is this? [Re: Clair_Davis] #89412
07/18/08 11:34 AM
07/18/08 11:34 AM
Andrewh Offline OP
Andrewh  Offline OP
well with the drilling for a new port, I can get rid of the stand pipe.
I guess the location of that sensor changes year to year.
In a different post, someone posted a pic of it to the right of the thermostat housing.
Mine is to the left of the stand pipe where the heater hose comes in to the manifold.
on the right of the thermostat housing is a raised flat place I plan on putting the new sensor.
So it shouldn't look as cobbled together as it did originally.
I think I can even do it without popping the intake off.
There doesn't seem to be anything on the otherside of it, so I am stuffing a rag behind it to catch the chips and shavings so I can drill and tap it on the block.
It is fairly easy with the thermostat out and the front of the motor off the engine.
Re: mag 5.9 sensor questions and what is this? [Re: Clair_Davis] #89413
07/18/08 11:39 AM
07/18/08 11:39 AM
Kalispell Mt.
HotRodDave Online content
HotRodDave  Online Content
Kalispell Mt.
What computer are they planning on useing? Why would they not make a harness to hook the mopar computer to the mopar engine? With a GM computer it will need programming just to run the bone stock engine not to mention souped up engines. At least the mopar computer would work with the mopar engine and then the whole what sensor, where to drill and tap crap would be a moot point. And there are plenty of shops that can program the mopar computer as well as many off the shelf controlers for mildly modified engines. Name me one Bone stock GM compurter that will run a bone stock 5.9 properly with out programing. I thought the whole deal was to make it "Painless"
Re: mag 5.9 sensor questions and what is this? [Re: HotRodDave] #89414
07/18/08 12:04 PM
07/18/08 12:04 PM
Andrewh Offline OP
Andrewh  Offline OP
It isn't a gm computer. They are using gm style sensors.
They gave me a set for water temp and air temp. They put on a knock sensor and that is it.
You could put the air temp sensor where the original one is, but he asked for it to be put in the air intake flow, so I am putting it in the air cleaner.
When they test fired the engine, they ran the cts in the stand pipe and looped it back to the inlet of the wp.
When I put the engine in my car, I realized that would not work since I don't turn on my heat.
So now he has asked me to drill and tap the intake to put the temp sensor in.
It is painless's computer, and they are reprogramming it so you can just hook it up to the injectors, coil, and distributer.
Add a bracket for something near the coil, put something in the distributer, and add the 3 sensors and you can fire it up.
I would not call it painful, just a little more than I expected. But way better than any of the diy and cheaper than any of the other store bought efi systems.
after all I am dropping it into a 65 coronet. I get the efi and serpentine belt setup to boot.
Not defending per se, just saying I don't think it is that bad. I would rather not have to drill and tap the intake, but it looks like I was going to have to anyway so my stock gauge would work anyway. So not as big a deal as I thought.
I also would like them to use the stock sensors, but they don't seem interested in that at this time.
Re: mag 5.9 sensor questions and what is this? [Re: Andrewh] #89415
07/18/08 12:37 PM
07/18/08 12:37 PM
Kalispell Mt.
Kalispell Mt.
I was under the impression they were makeing a harness to hook a factory style computer so any one could hook up EFI, I guess that is sort of what they are doing but useing there own computer adding to the $$$ per sale and subtracting from there # of sales.
Is there any harness available to take a JY engine and JY computer and hook it easily and directly into an older car? Shouldn't be that hard for one of the wiring gu-roos to whip up and sell a ton of
On another subject why is a dead head EFI a bad thing? Why should we all run return lines?
Re: mag 5.9 sensor questions and what is this? [Re: HotRodDave] #89416
07/18/08 12:44 PM
07/18/08 12:44 PM
Andrewh Offline OP
Andrewh  Offline OP
There is no solution like that as I understand it.
Multiple problems occur due to the sensors that are missing or not used by the jy computer.
I just got off the phone with painless after asking about the mapping of the stock sensors. Apparently a sore subject. They have been down this road with the ford guys and they still use gm sensors.
The months of time it would take to map out the old sensors and get them working is not worth the 30 bucks the end user saves.
Dead head vs return line is a whole different debate, and has several reasons for not running dead head as I understand it.
Better pump life, better fuel pressure response, not as much crud built up in the fuel rails.
As for the coolant sensor thing, since I am the gunie pig(sp), I will tap a hole for the sensor and plug it. Use the stand pipe for now, and see how much different it is with coolant running or not. Then if they find it different enough to require tapping the intake, mine is already switched out for it.
I may run it like that anyway since it looks cleaner regardless of what they find.
Also it looks like I would have to tap it for the old(65 cts) sensor anyway.
Re: mag 5.9 sensor questions and what is this? [Re: Andrewh] #89417
07/18/08 03:37 PM
07/18/08 03:37 PM
Cali S.B
Sub95 Offline
super gas
Sub95  Offline
super gas
Cali S.B
On my 95 i have 2 sensors one on the left and right side of the thermostat, one is for temp gauge and one is for the computer on the pic i posted that is off a 99 ram that i got on a engine and you can see where they put the single sensor at.
Re: mag 5.9 sensor questions and what is this? [Re: HotRodDave] #89418
07/18/08 04:06 PM
07/18/08 04:06 PM
Dirty South, MS
mopowered Offline
mopowered  Offline
Dirty South, MS
Yes actually there is - Autonomics sells one for the MegaSquirt Computer. Any Sensors/Injectors/FuelSystem -> Generic Computer -> Any engine. Or you can just scrap up some 10, 14 and 18-22ga wire and build one yourself. Just be sure to grab the sensor/injector connectors when you pick out those components to attach to your wiring harness.
I'd like to hear more on this also. I personally prefer return systems for all the reasons mentioned but most of the OEM's have all switched to the dead-head style...
Re: mag 5.9 sensor questions and what is this? [Re: mopowered] #89419
07/18/08 04:16 PM
07/18/08 04:16 PM
Andrewh Offline OP
Andrewh  Offline OP
They run it because it is cheaper.
Seriously in return line material alone they save money.
These are the people that deleted the cig lighter to save 50 cents a car.
From the hose clamps, the line, hose, and so forth, they must save close to 20 cents per car leaving that out.
Re: mag 5.9 sensor questions and what is this? [Re: Andrewh] #89420
07/18/08 05:42 PM
07/18/08 05:42 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
I understand that there's an emissions aspect to it as well, but I can't recall what it was. The systems are essentially sealed any more, so I'm not sure how it would be a benefit. Between the speed of assembly and the $0.20 saved per car, you're really talking about serious bucks after a few million cars...
Clair
