Re: ss/ah hemi heads
[Re: robnbird]
#894065
01/02/11 12:10 AM
01/02/11 12:10 AM
Dyno1
[Re: robnbird]
#894067
01/02/11 04:15 AM
01/02/11 04:15 AM
Posts: 11,820 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Porting, polishing, welding, epoxying, acid porting permitted. Grinding and polishing of combustion chamber permitted. Stock size valves, stock location and angles for spark plugs and valve guides.
Intake port max. volume 189cc, exhaust port max. volume 107cc, chamber volume 167.7cc min.
[Re: robnbird]
#894068
01/02/11 09:05 AM
01/02/11 09:05 AM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
do I understand the nhra porting, polishing,welding,epoxying, and acid-porting permitted. man that sounds unlimited. did the hemi have sodium filled valves?
No
[Re: robnbird]
#894072
01/03/11 03:51 PM
01/03/11 03:51 PM
Posts: 3,505 DFW
mr_340
DFW
The recent article said that Barton was charging $15k for a set of heads. I saw stacks of them at his shop when I stopped in over the summer. Lots of brass in the runners. I think MCH was around $8k, but that was many years ago. I don't know what Warfishy heads cost. Out of my league either way.
Floyd Lippencott IV
