318 2bbl to 4bbl. Need diff throttle bracket? #89318
07/16/08 12:01 AM
07/16/08 12:01 AM
RapidRobert Offline OP
going from carter 2bbl(BBD ) to holley 6oo(1850). do I need a diff throttle bracket or can I bend the 2bbl one? thank you for your time.
Re: 318 2bbl to 4bbl. Need diff throttle bracket? [Re: RapidRobert] #89319
07/16/08 04:12 AM
07/16/08 04:12 AM
places
79powerwagon Offline
places
So the BBD is hitting the ocean after-all? Good for you!
I used the stock bracket on a truck, I simply had to slide the throttle cable rear-ward a bit (it still clamped in place), and make a $0.10 modification to the KD linkage.
Same for my 64 Fury with a poly 318...
Re: 318 2bbl to 4bbl. Need diff throttle bracket? [Re: 79powerwagon] #89320
07/16/08 09:13 AM
07/16/08 09:13 AM
YES I am finally admitting defeat
Re: 318 2bbl to 4bbl. Need diff throttle bracket? [Re: RapidRobert] #89321
07/16/08 09:20 AM
07/16/08 09:20 AM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Good riddance.
Yes, you'll need either a carb throttle arm bracket or you'll need to make a custom setup since the 4-bbl is narrower than the 4-bbl.
If you want proper throttle cable and kickdown rod/cable alignment, you should get a 4-bbl throttle cable bracket, too.
Re: 318 2bbl to 4bbl. Need diff throttle bracket? [Re: In_The_Pink] #89322
07/16/08 12:42 PM
07/16/08 12:42 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
The only 4-barrel that I know of that will work with the 2-barrel linkage is a Holley.
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: 318 2bbl to 4bbl. Need diff throttle bracket? [Re: RapidRobert] #89323
07/16/08 12:43 PM
07/16/08 12:43 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
not to mention the 4 barrel carb lever is farther forward than on a 2 bbl
Re: 318 2bbl to 4bbl. Need diff throttle bracket? [Re: gtx6970] #89324
07/16/08 02:35 PM
07/16/08 02:35 PM
Alright so I'm going to need a 4bbl bracket to make this carter 2bbl to holley 4bbl swap work?
Re: 318 2bbl to 4bbl. Need diff throttle bracket? [Re: RapidRobert] #89325
07/16/08 10:38 PM
07/16/08 10:38 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
here is what i did
before:
after:
Re: 318 2bbl to 4bbl. Need diff throttle bracket? [Re: west] #89326
07/16/08 10:56 PM
07/16/08 10:56 PM
West,thank you!
Re: 318 2bbl to 4bbl. Need diff throttle bracket? [Re: RapidRobert] #89327
07/16/08 10:59 PM
07/16/08 10:59 PM
Andrewh Offline
Andrewh  Offline
pretty sure you need a new kick down arm too.
Re: 318 2bbl to 4bbl. Need diff throttle bracket? [Re: Andrewh] #89328
07/17/08 03:22 PM
07/17/08 03:22 PM
London, England
Gavin Offline
Gavin  Offline
London, England
You can mod that as well
Re: 318 2bbl to 4bbl. Need diff throttle bracket? [Re: Gavin] #89329
07/17/08 04:05 PM
07/17/08 04:05 PM
what I have now is the std (3) piece setup.
Re: 318 2bbl to 4bbl. Need diff throttle bracket? [Re: RapidRobert] #89330
07/17/08 10:11 PM
07/17/08 10:11 PM
5thAve Offline
5thAve  Offline
You can modify the 2 barrel bracket to work. It needs to be bent farther out and made longer. I had to do that to mine but already had the right rod.
