Re: rocker arms
[Re: sqrelnts]
#892941
12/31/10 11:23 PM
12/31/10 11:23 PM
Posts: 52,972 Romeo MI
MR_P_BODY
For your .550 lift I would check the 273 adjustable you have for proper ratio and if they are close I'd run them ![](/ubbthreads/images/graemlins/wave.gif)
Re: rocker arms
[Re: ahy]
#892942
12/31/10 11:27 PM
12/31/10 11:27 PM
Posts: 1,532 off the grid
340B5
off the grid
The Comp Ultra Pro Magnum sounds like the ticket here. They're made of 8620 nickel chromemoly steel.
Yeah, it's got a smallblock.
Re: rocker arms
[Re: 340B5]
#892943
12/31/10 11:39 PM
12/31/10 11:39 PM
Posts: 84 IA
sqrelnts
IA
can anyone confirm weather or not the crane or isky ductile rockers are bushed or not? maybe just a good hardened banana grooved shaft would be the best defence against galling on a non-bushed rocker? The comp ultra pros would prob work well, i guess it would just be weather the extra couple hundred $ and a roller tip would be any significant gain in hp and wear.
Re: rocker arms
[Re: sqrelnts]
#892944
12/31/10 11:49 PM
12/31/10 11:49 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
the crane ductile irons are not bushed.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
