Honing cylinders recommendation needed! #892747
12/31/10 04:34 PM
12/31/10 04:34 PM
Penna
70satelliteguy Offline OP
Penna
After teardown this winter my motor looked really good so I am just going to replace bearings and rings. I bought a honing tool from Harbor freight to hone my cylinders myself. There are no instructions with the tool.
Do use a special honing oil to do this and how do I know how much honing to do? The cylinders also look good so I just want to put a finish on the that will allow the new rings to seat properly.
Thanks Mike
Re: Honing cylinders recommendation needed! [Re: 70satelliteguy] #892748
12/31/10 04:36 PM
12/31/10 04:36 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Its kinda tricky to get the correct cross hatch like 30°- 40° or so for proper ring seat.. You have to run the drill at lower speeds and work the hone up and down in the cylinder a decent speed at the same time.
Re: Honing cylinders recommendation needed! [Re: 70satelliteguy] #892749
12/31/10 04:38 PM
12/31/10 04:38 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
on a booger hone job i use wd-40 as hone lube/cleaner, with drill hone. for any performance motor right on a real hone machine
MOPAR OR NO CAR
Re: Honing cylinders recommendation needed! [Re: 70satelliteguy] #892750
12/31/10 04:41 PM
12/31/10 04:41 PM
Was the block honed with a torque plate before? If so don't rehone it without the plate and same type and brand head gaskets What type of hone is it, ball or mechanical with long stones? Harbor Frieght tools are not the best when it comes to making good results
Re: Honing cylinders recommendation needed! [Re: 70satelliteguy] #892751
12/31/10 04:46 PM
12/31/10 04:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
First your just deglasing the walls its not a hone
but try for 30* cross.... you will be moving up and
down pretty quick at a fairly low rpm
Re: Honing cylinders recommendation needed! [Re: MR_P_BODY] #892752
12/31/10 04:54 PM
12/31/10 04:54 PM
Penna
Penna
yes MR P Body I guess I am just deglassing the walls! The cylinders were professionally honed 2 years ago at the maching shop.
How do I get a 30 deg angle???
Thanks Mike
Re: Honing cylinders recommendation needed! [Re: 70satelliteguy] #892753
12/31/10 05:09 PM
12/31/10 05:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks Mike
LOL... its a up and down (pretty quick ) with a fairly
slow rpm on the drill... you'll see the marks after
a few strokes and either adjust the stroke speed(your
arm) or the rpm of the drill
Re: Honing cylinders recommendation needed! [Re: MR_P_BODY] #892754
12/31/10 05:22 PM
12/31/10 05:22 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
like said you have to move up and down pretty guick and its easy to accidently go to far up or down and the stones break or go flyin.(at least thats what ive heard )
