Page 2 of 3 1 2 3
Re: GearVendor installation in my 1969 Charger Daytona.. [Re: hemi68charger] #892406
01/03/11 11:35 PM
01/03/11 11:35 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
When I put mine in my Challenger, I slid the new yoke in till it bottomed out. Then slid it back out 5/8 of an inch, and measured from center to center on the u joint holes of both yokes. Took that measurement to the driveshaft shop to get the new driveshaft made. The electronic box seems to be the weak link of the system. Check with the GV tech dude to see if yours will live behind that kick panel. Might build too much heat.
Re: GearVendor installation in my 1969 Charger Daytona.. [Re: Spaceman Spiff] #892407
01/03/11 11:48 PM
01/03/11 11:48 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Maybe I missed it but what supports the unit other than the crossmember?
The GV unit is bolted straight to the GV tailshaft housing. That's it. Apparently it's strong enough. I haven't heard of anyone breaking one yet.
I think that's one of the suggested places. I'll double check. I guess I should drive it a while and check the control box for heat dissipation. The measurement scheme I used would have worked, it was the shop that messed it up by cutting off 13" versus the 14" I asked them to do.... They were cool about it this afternoon when I dropped it off..
Troy
Houston Mopar Connection Club
Re: GearVendor installation in my 1969 Charger Daytona.. [Re: hemi68charger] #892408
01/04/11 12:23 AM
01/04/11 12:23 AM
JDMopar Offline
JDMopar  Offline
After I had a control box fail, I ran a spare wire from the foot switch down to the solenoid on the unit. I crimped an end on it, and then just taped it up and left it loose. Did the same at the foot switch end, and also ran a spare to the fuse block to supply 12V to the foot switch. All the solenoid needs is 12V to operate, so I can still get the OD to engage if the box ever takes a dump again. The split shifting was fun for the first 5 minutes, but I just use mine for OD now! Good luck, and you did a super nice job on the install.
Re: GearVendor installation in my 1969 Charger Daytona.. [Re: 602heavy] #892409
01/04/11 12:24 AM
01/04/11 12:24 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Those GVs are bullet proof , had one on the 68 charger , stripped the planetries out before the box got hurt , 4400lb charger constantly put through it's paces @ the track , only issues i had was a control module go bad , GVs sent me one out within a couple days , great aftersales service.................nice work there MickRR.
I wouldn't call them bulletproof , I know a guy that blew up at least one behind a 12v Cummins diesel that was putting over 400 HP to the ground through a 5 speed manual trans towing 29k lb. horse trailers, but most gas engines aren't making the kind of torque a Cummins makes.
Re: GearVendor installation in my 1969 Charger Daytona.. [Re: JohnRR] #892410
01/04/11 05:58 AM
01/04/11 05:58 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Memories of installing mine...I had the same problem in the tunnel with the fitment of the OD unit. Still though, I hate working on transmissions and rear axles. The instructions were simple, easy to read. Took me 6 hours to install on a Saturday plus the waiting of a business day following for the driveshaft work.
Only problem I have is that my H-Pipe sits right on the GV unit where the finned part of the housing is. My exhaust melted the gasket. I still haven't gotten around to relocating the crossover. I have bought 2 spare gaskets just in case.
Only think I can't figure out is the split shifting. 1st (Gear 1), switch (Gear 1.5).....switch/2nd (Gear 2), switch (Gear 3).....switch/3rd (Gear 3.5 / OD)....switch
I can't get the sync right...but I don't drag race it enough to utilize that option, I just hit the button and go to OD....Final driving speed is 80mph @2100 rpm with 3.55s and 28" rear overall tire.
Great job on the documentation. I had documented mine but upon carrying my SD card from my camera to the computer....fell in a tub of tranny fluid at the shop I did it in....toasted
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: GearVendor installation in my 1969 Charger Daytona.. [Re: JohnRR] #892411
01/04/11 08:06 AM
01/04/11 08:06 AM
UK
602heavy Offline
602heavy  Offline
UK
Well , i'm talking about a 4400lb B body , 605" running nitrous , circa 950hp , maybe not a cummins.
Re: GearVendor installation in my 1969 Charger Daytona.. [Re: 602heavy] #892412
01/04/11 05:56 PM
01/04/11 05:56 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
Since blowing my overdrive up I've done a fair bit of reading about this style of overdrive and there's a few things you should bear in mind. First of all a 4 speed is going to be a lot harder on the overdrive because there's no torque converter to soften the blow when the cone clutch engages. When driving around town I tend to dip the clutch just after I hit the switch because at low speed/part throttle it bangs in even harder.
With the overdrive switched out, the drive is taken up by a one way roller clutch when accelerating or cruising so it's not going to slip. In reverse or on the overrun, the one way roller clutch does nothing and drive is through the cone clutch which is held against the annulus with low fluid pressure. The cone can slip under heavy acceleration in reverse or on the overrun so engine braking should be avoided if the overdrive is switched out. When the overdrive is engaged, the cone clutch is held against the clutch band using very high fluid pressure (about 700psi) so it's not going to slip on the overrun. With that in mind I always slow the car down with the overdrive engaged and let it drop out automatically at about 15mph.
The other thing I do now is regularly change the fluid. There's a drain plug fitted as standard to my overdrive so I don't even have to drop the pan and it only takes about half an hour.
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
Re: GearVendor installation in my 1969 Charger Daytona.. [Re: gtx6970] #892413
01/04/11 11:24 PM
01/04/11 11:24 PM
Bucks County, PA
500Stroker Offline
500Stroker  Offline
Bucks County, PA
So, the system doesn't kick down, aka out of overdrive on accel ?
I assume the regular trans still does, so technially the trans is in 2nd , yet the OD is still engaged.
Correct. With my 3:55's on the highway in 3rd OD the regular trans still kicks down at 70 mph and does not go into 3rd until 105 mph if I keep the petal to the floor.
Re: GearVendor installation in my 1969 Charger Daytona.. [Re: JDMopar] #892414
01/04/11 11:33 PM
01/04/11 11:33 PM
Bucks County, PA
500Stroker Offline
500Stroker  Offline
Bucks County, PA
I mounted mine up under the steering column behind the gauges
Re: GearVendor installation in my 1969 Charger Daytona.. [Re: 500Stroker] #892415
01/05/11 12:47 AM
01/05/11 12:47 AM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
I had used Houston Drivetrain for 30 years w/no problems. The last shaft I had them make(6/10) took them three tries to get right and I had even gone so far as to print off a sheet from Denny's driveshafts with all measurements in hope of preventing just this. When it developed a vibration after 5k miles they fixed it but tried to tell me that heat from my TTI exhaust had warped it! We put a Dana in my buddies car and they screwed up on shortening his shaft also, it took two tries. They used to have some sharp folks there, but I am finding another shop.
Re: GearVendor installation in my 1969 Charger Daytona.. [Re: hemi68charger] #892416
01/08/11 12:40 AM
01/08/11 12:40 AM
Houston, Tx
Houston, Tx
I've updated steps 25 - 28 in up top......... Getting closer......
Troy
Re: GearVendor installation in my 1969 Charger Daytona.. [Re: hemi68charger] #892417
01/08/11 09:12 AM
01/08/11 09:12 AM
Northern Va
Mopar73340 Offline
Mopar73340  Offline
Northern Va
Nice documentation. I installed the GV unit in my E-Body last March and as you document it is pretty straight forward. I had no issues with driveshaft angles just bolting the unit in place. There was some minor clearance issuses with the tunnel as you describe, but that was it. I use it 99% in auto mode and it does not alter the way the transmission works, there is just one more shift about 45 mph. I ended up using a toggle switch in the dash to control the shifts when I decide I want to instead of the floor mounted switch supplied with the kit. I am completely satisfied with it and if I had it to over again I would. I would even have used it in my 4-spd car behind the 833 instead of the Keisler unit that's in there had I converted my auto car first. I'm sure you are going to be happy with the unit.
Re: GearVendor installation in my 1969 Charger Daytona.. [Re: hemi68charger] #892418
01/08/11 12:44 PM
01/08/11 12:44 PM
Ozona, Texas
P
Paladin Offline
Paladin  Offline
P
Ozona, Texas
Troy,
I want to thank you so much for taking the time and effort to document this. I scored a nice Gear Vendors unit for $400 a while back with a T-19 adapter. I plan on installing it in my '71 R/T this summer while Levi and Ethan are home on leave from Annapolis. I am going with a simple on/off switch, as I plan on using it as a simple overdrive so I can replace my 2.76s with 3.23s.
Again, I personally appreciate what you did here. As the old saying goes, a picture is worth a thousand words.
May God bless America,
"Paladin"
Ben H. English
Ozona, Texas
1971 Dodge Charger R/T
1977 Chrysler Cordoba A35
1979 Dodge Lil� Red Express
1981 Chevrolet Corvette
1985 Chevrolet Corvette
1986 Chevrolet Corvette Roadster
1994 Lincoln Mark VIII
1998 Dodge Ram 2500 Sport V10
Re: GearVendor installation in my 1969 Charger Daytona.. [Re: Paladin] #892419
01/09/11 04:34 AM
01/09/11 04:34 AM
Bucks County, PA
500Stroker Offline
500Stroker  Offline
Bucks County, PA
Nice write up and pictures.
Did your instructions tell you to use Dextron ATF?
I was always told not to use that.
Searching the web I found this write up. Which is what I have always used.
The overdrive is shipped without transmission fluid in the unit. Remove the 13mm fill
plug on the back right side of the overdrive and add approximately 26 ounces of synthetic
manual transmission fluid (GM part #12346190 or Mopar #0487-4459). Fill to the
bottom threads of the plug. Gear Vendors specifically recommends GM# 12346190, or
Mopar #0487-4459, and it should not be substituted.
Gear Vendors previously recommended Dexron II automatic transmission fluid for its
overdrive units. It now recommends the GM synthetic manual transmission fluid for its
overdrive units due to improved shift characteristics, and less thinning at temperature
than Dexron automatic transmission fluid.
GV's website says - Fluid type - GM#1052271 petroleum based or GM#12346190 synthetic.
Re: GearVendor installation in my 1969 Charger Daytona.. [Re: 500Stroker] #892420
01/09/11 07:46 AM
01/09/11 07:46 AM
Houston, Tx
Houston, Tx
Ken, thanks for the head's up. The Dexron II ATF is right out of their installation manual. But, maybe it hasn't been updated. It's worth a call to them to verify since I haven't gotten it out on the road yet. I'll try to check out their website this afternoon.
Troy
Re: GearVendor installation in my 1969 Charger Daytona.. [Re: JDMopar] #892421
01/09/11 12:41 PM
01/09/11 12:41 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
I have a reverse manual valve body in my 69 Bee. I leave the GV in manual and drive it like a four speed. I never put muy controller in auto. I don’t like the GV engaging automatically at 45 mph. As far as spit shifting goes it’s a waist of time and isn’t all that effective. When I want to pass I just go to second with the over drive engaged and hit the go peddle. I believe my control box is starting to go so I’m going to wire it direct through the foot switch like JDMOPAR did. I don’t really need the control box as long as I remember to disengage the GV when I stop. I called GV to ask them about using Dexron II, they said it will work with out any problems. But I did replace it with the GM gear lube. My GV installation book had a sticker on the front cover addressing the suggested change from Dexron II to the GM syntactic
Re: GearVendor installation in my 1969 Charger Daytona.. [Re: hemi68charger] #892422
01/09/11 12:46 PM
01/09/11 12:46 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
I think the recommendation depends on the local climate. Rick Johnson told me to use a 50/50 mix of Dexron II (or any ATF) and 75/90 GL4 here in the UK.
Re: GearVendor installation in my 1969 Charger Daytona.. [Re: hemi68charger] #892423
01/09/11 12:55 PM
01/09/11 12:55 PM
JDMopar Offline
JDMopar  Offline
Troy...I read right over the part about you using the Dexron. I originally purchased my GV for a D350 pickup, and installed it in that truck. My installation manual also had the sticker saying to use the GM petro or synthetic. I used the petro oil while it was in the truck. When I bought my 04 Dodge 2500, I pulled the GV out of my old truck and sold the truck. A few years later, I put the GV in my 71 GY3 Challenger. This time I used the synthetic GM fluid, and I'm much happier with the way it shifts. The Dexron probably wouldn't hurt yours,but I'd check with the GV techs to see.
Re: GearVendor installation in my 1969 Charger Daytona.. [Re: JDMopar] #892424
01/18/11 11:55 PM
01/18/11 11:55 PM
Houston, Tx
Houston, Tx
Wow... What a difference....... I drove the Daytona this afternoon making sure all the "t's were crossed and "i's" dotted. Here are two videos of the cruise. Sorry about the quality and only being inside, but can't take outside videos when one's driving..... The unit has done everything as advertised. Engaged and disengaged right on queue. Seemed to drive smooth without any differential adjustment to any driveline angles. So far, quite pleased. I'll put a few more miles on her then check the gearlube and all wires and speedo-cable for any clearance issues...
Down the street by the house....
http://www.youtube.com/watch?v=W2OStFjZazc
Down the feeder road......
http://www.youtube.com/watch?v=9yPGInia5Lw
Troy
Re: GearVendor installation in my 1969 Charger Daytona.. [Re: hemi68charger] #892425
01/19/11 12:09 AM
01/19/11 12:09 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Glad to hear everything's working out...With a 4.10 rear you'll have the best of both worlds now !
Page 2 of 3 1 2 3
