Re: .557 lift in a 408 stroker
[Re: Quicktree]
#892259
12/31/10 11:25 AM
12/31/10 11:25 AM
Posts: 10,038 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Leigh, member of this board ran it in a bracket race 360 for many years in his 69 dart. Went mid elevens. If he's on line I bet he will post all his motor stats for you.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: Bishop]
#892260
12/31/10 12:53 PM
12/31/10 12:53 PM
Posts: 7,506 Az
Crizila
Az
Do you have the specs on that cam?
Fastest 300
[Re: Bishop]
#892261
12/31/10 01:02 PM
12/31/10 01:02 PM
Posts: 8,165 Left Coast
BobR
Left Coast
I'm buidling a 408(360)stroker with Edelbrock Alum. heads I have a .508 hyd cam for the motor now but was thinking about putting a .557 solid lift cam instead. The motor is going down in a 71 Demon that is basically going to be driven on the street only taken to the strip to see what it can run. Good idea or bad idea?
Thanks Brian
If it's not a roller I won't use it. I'm sure I'll get a lot of disagreement.
[Re: greendart408]
#892263
12/31/10 01:40 PM
12/31/10 01:40 PM
Posts: 915 Cincinnati OH
Bishop
Cincinnati OH
Part #4120655 .557/.557 lift 296 Duration
[Re: Bishop]
#892267
01/03/11 12:08 AM
01/03/11 12:08 AM
Posts: 147 Milledgeville, (central) Georg...
Bighead440
I had someone PM told me to try A D.C. .590 instead of a .557, do you guys think that would be to big for basically a street car?
In my opinion, a MP .590" cam is too radical and has too tight of a lobe separation (LSA) to be ideal in your setup. The .557" is close on the LSA but too small, I think you just ought to investigate a wider LSA (110-112deg.) for your stroker. I had a 110 with aggressive (short seat duration) lobes and mine was real forgiving. Maybe get with Lunati, CompCams, Engle or Bullet/Ultradyne and see what they recommend. I know people are gonna argue with this, but if you really intend to street drive this, even a big cam with a wider LSA is going to be more friendly... RB
