'92 Spirit trouble, TPS gone bad? #89216
07/15/08 09:24 PM
07/15/08 09:24 PM
Between Houston & Galveston TX
SattyNoCar Online work OP
SattyNoCar  Online Work OP
Car in question is my Mom's '92 Spirit with the 2.5, has 90K miles on it.
With no rhyme or reason, the car will momentarily surge then loose power while at speed (usually 50 or faster). It never completly stalls, just looses RPM's. Working the gas, the car will kinda 'jump' then sputter a few times, then 'catch' and act as if nothing happened. Around town, 40 or slower, the problem never shows.
This happened once before about 6 months ago. With the way the car acted by working the gas, I just put a TPS on it. Car ran much better afterward, even better than before the problem showed up. Car has run fine until today.
Could it be a bad TPS? Yeah, I threw on a 'house brand' last time. Has it come back to bite me in the rear?
Would a bad TPS set off the check engine light? Its not on and didn't come on last time either.
Anything else I should look at?
Thanks.
John
Re: '92 Spirit trouble, TPS gone bad? [Re: SattyNoCar] #89217
07/15/08 11:23 PM
07/15/08 11:23 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Your computer reads reference voltage from the TPS. Should range from around .75 to 5 volts depending on the postion of the pedal/TPS.
If you take your foot off the pedal it won't set a code right? So a TPS can cause trouble and not set a code. Use a meter and make a back probe out of a sewing needle to check it at the terminals of the TPS. Sweep the throttle up and down and check it. If it's consistant and seems to have no issue it still could be intermitant
Re: '92 Spirit trouble, TPS gone bad? [Re: UCUDANT] #89218
07/16/08 07:32 AM
07/16/08 07:32 AM
Thanks!
John
Re: '92 Spirit trouble, TPS gone bad? [Re: SattyNoCar] #89219
07/17/08 09:29 PM
07/17/08 09:29 PM
Well, the problem hasn't happened again. Since it never completly dies, she's been driving it as usual (actually put over 150 miles on it since I first posted).
If/when it acts up again, I'll be at the ready.
John
