another 360 question #89208
07/15/08 09:16 PM
07/15/08 09:16 PM
south jersey
474dodge Offline OP
474dodge  Offline OP
south jersey
just scored a 2001 5.9 magnum, are the early j series heads interchangeable,i thought i heard they do but i would have to use a cam and lifter setup from an earlier 318-340-360's.
Re: another 360 question [Re: 474dodge] #89209
07/15/08 09:46 PM
07/15/08 09:46 PM
with rocker shaft heads you can tap oil from the oil pressure sending unit on the back of the block & drill horizontally in the back of each head & then angle up to feed oil up to a rocker shaft bolt,from there on it's just like the factory setup.
Re: another 360 question [Re: RapidRobert] #89210
07/15/08 10:50 PM
07/15/08 10:50 PM
dogdays Offline
dogdays  Offline
As the Mag heads are better than any stock LA head why would you use the LA heads?
The roller cam can be reground for a reasonable fee and use the stock lifters and oushrods, unless you go wild on the cam in which case you may need longer pushrods.
R.
