Help me id this transmission #891343
12/29/10 07:25 PM
12/29/10 07:25 PM
Crofton, MD
bri440 Offline OP
bri440  Offline OP
Crofton, MD
I was searching through the junkyard today, looking for a A518 transmission. I found one in what I believe is/was a 1994 Ram 50 pickup with a 5.9 engine. This is based on the emission stickers in the engine bay. The VIN/dash is gone. The thing that is throwing me is the transmission has a large "X" cast in the case behind the bell housing. The "X" goes from left to right across the top. The pictures I've seen on the internet don't show the "X" in the case. In the picture, the A518 is suppose be on the left. The transmission I was looking at doesn't have that cluster of webbing on the right side. It also doesn't match the transmission on the right side of the picture either, I think that is suppose to be a A500.
Thanks,
Re: Help me id this transmission [Re: bri440] #891344
12/29/10 07:31 PM
12/29/10 07:31 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
A ram 50 ??? that wouldn't have a 360 . do you mean 150 ?
A518 has the same bump out on the pass side of the trans case like a 727 ... they both use the same pan gasket... the A500 does not , it's a 904 based trans .
Re: Help me id this transmission [Re: JohnRR] #891345
12/29/10 07:50 PM
12/29/10 07:50 PM
Crofton, MD
bri440 Offline OP
bri440  Offline OP
Crofton, MD
Yeah, you're right - 150 its a full size truck.
Thanks,
Re: Help me id this transmission [Re: bri440] #891346
12/29/10 08:26 PM
12/29/10 08:26 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Left trans is 518 od, center trans is 727 possibly from a van w/hole in bell., right one looks like a 500 od.
Re: Help me id this transmission [Re: buildanother] #891347
12/29/10 09:07 PM
12/29/10 09:07 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
correct but the a500 on the right appears to be out of a jeep.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
