mtr. assymbelly questions #891046
12/29/10 10:19 AM
12/29/10 10:19 AM
S.E. Wisconsin
darepairman Offline OP
S.E. Wisconsin
I have a few questions about the assembelly of my 318, First off what is better to use assy. grease or oil on the bearings I have heard 2 different stories on this, keep in mind the motor will sit for about 6 months. Second, my harmonic balancer has a stripped hole for the crank pully, would a helicoil mess the balance up? and if I get another balancer do I need an internal balancer or external? oh ya its a 1972.
The Event Horizon is on its way
Re: mtr. assymbelly questions [Re: darepairman] #891047
12/29/10 10:57 AM
12/29/10 10:57 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
To start with
Grease, preferably assembly lube or molybdenum disulphide based grease. Use oil on threads to ensure a more accurate torque value, but for bearings oil will not do, especially waiting 6 months. Before you fire it up, preoil the engine.
As for the balancer, helicoil it. If you do go with a new one, all 318's are internally balanced.
Don't be the exception.
Re: mtr. assymbelly questions [Re: Supercuda] #891048
12/29/10 11:04 AM
12/29/10 11:04 AM
S.E. Wisconsin
S.E. Wisconsin
Thanks for the info. Ed
Re: mtr. assymbelly questions [Re: darepairman] #891049
12/30/10 02:39 AM
12/30/10 02:39 AM
Boise Idaho
Boise Chall Offline
Boise Chall  Offline
Boise Idaho
And put a POOPERCUDA spring in the lower radiator hose hahahha
Re: mtr. assymbelly questions [Re: Boise Chall] #891050
12/30/10 11:19 AM
12/30/10 11:19 AM
S.E. Wisconsin
S.E. Wisconsin
Why I oughddda!!!!
Re: mtr. assymbelly questions [Re: Boise Chall] #891051
12/30/10 11:29 AM
12/30/10 11:29 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Only listen to the Idaho D-bag if you want an unending litany of moronic mistakes, errors and expensive stumbles.
Re: mtr. assymbelly questions [Re: Supercuda] #891052
12/30/10 11:33 AM
12/30/10 11:33 AM
Boise Idaho
Boise Chall Offline
Boise Chall  Offline
Boise Idaho
I will say this poopercuda we do agree on a couple things I don't like Tattoo's on girls either and I prefer my girls thick not like twigs or as Kid Rock said it " Skinny models you can keep those I like big corn fed mid western HO's "
Re: mtr. assymbelly questions [Re: Boise Chall] #891053
12/30/10 11:47 AM
12/30/10 11:47 AM
S.E. Wisconsin
S.E. Wisconsin
Sorry boys, I didnt get the poopercuda spring referance, Thought it was like a muffler bearing or a diddle bushing. Carry on. Ed
Re: mtr. assymbelly questions [Re: darepairman] #891054
12/30/10 01:27 PM
12/30/10 01:27 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't worry about it, Ed. You got caught in the middle of something else. Seems someone doesn't understand the difference between a band aid and a cure, but that someone isn't you, or me.
Re: mtr. assymbelly questions [Re: Supercuda] #891055
12/30/10 02:52 PM
12/30/10 02:52 PM
Boise Idaho
Boise Chall Offline
Boise Chall  Offline
Boise Idaho
You mean like replace an entire cooling system to find out the problem was the lower radiator hose was collapsing causing the problem. Your comebacks are getting a little better poopercuda having a 2 year old write them for you is definitely working for you. Now that's 2 solutions that solved a problem that I'm sure you won't agree with.
Re: mtr. assymbelly questions [Re: Boise Chall] #891056
12/30/10 03:03 PM
12/30/10 03:03 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Will you two children take it into PMs and get out of this thread?
- Stu Harmon
