trans code P1762 #891043
12/29/10 10:14 AM
12/29/10 10:14 AM
Fla
birdboy Offline OP
birdboy  Offline OP
Fla
starts out in 1st and takes long to shift. auto zone said it is a gov pressure sensor. would you change the sol # 4617210 or the transducer # 56028196ad. hate to throw both at it. thanks for the help.
Re: trans code P1762 [Re: birdboy] #891044
12/29/10 10:51 AM
12/29/10 10:51 AM
Ohio
Todd Offline
Todd  Offline
Ohio
I would change both their right beside each other.
Re: trans code P1762 [Re: Todd] #891045
12/29/10 10:57 AM
12/29/10 10:57 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I always change both.
The one time I didn't, the customer brought it back the next day with the same symptons.
now it gets both or I don't do it at all
