Top end oil restriction #890766
12/28/10 09:59 PM
12/28/10 09:59 PM
WA
JD Dart Offline OP
JD Dart  Offline OP
WA
I'm putting in a new cam need to go faster. My old comp cam did not have the curve around the #4 cam bearing. The new one has, does anyone know how much restriction I should put in.
Never had a problem before on the shut down at the top end. Thanks
Re: Top end oil restriction [Re: JD Dart] #890767
12/28/10 11:34 PM
12/28/10 11:34 PM
I've used .120,.080, .060 in the stock oil galleys to the heads using ductile iron rockers and .039 in my Indy headed motors with Harland Sharp and T&D roller rockers and a grooved # 4 cam journal I help a local racer with a set of Indy 440-1 that fought the same problems on his motor on the dyno, loosing oil pressure do to insuffeceint oil return so I started my Indy headed motors at .039 in the pressure lines to the heads What type rockers are you using now? The World iron blocks have a .040 restritor in there oil galleys to the heads
Re: Top end oil restriction [Re: Cab_Burge] #890768
12/28/10 11:47 PM
12/28/10 11:47 PM
WA
JD Dart Offline OP
JD Dart  Offline OP
WA
T&D rockers Thanks for the good advice. So you just put the .039 in the heads and not the block it really should'nt matter were it's at. With the heads off should be easy.
Re: Top end oil restriction [Re: JD Dart] #890769
12/29/10 12:09 AM
12/29/10 12:09 AM
I've drilled the blocks so a Holley jet wil fit and I've done the same thing to the heads, your choice The Indy heads have seperate oil lines from the back of the block oil galley passages to each head, not sure if you knew about that. My message is the blocks I have restricted had grooved cam journals, .030 wide and close to .030 deep, not the same flow capicitys as the external oil lines like the Indy heads use I would, and have, use a .060 in the block first, way better to have a little to much oil feeding than not quite enough
Re: Top end oil restriction [Re: JD Dart] #890770
12/29/10 04:11 AM
12/29/10 04:11 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
With T&D rockers just use regular hold down bolts, not the under cut studs, and that will restrict oil flow to the rockers
Just joking, I've been fighting rocker issues for the last few months, and today the Heli-coil insert pulled out of the head (I think the rocker arm bolt was too short?)
Re: Top end oil restriction [Re: 451Mopar] #890771
12/29/10 04:16 AM
12/29/10 04:16 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
ANYone done a test on how restricting oil to the heads affects valve-spring life?
Re: Top end oil restriction [Re: dOoC] #890772
12/29/10 08:53 PM
12/29/10 08:53 PM
WA
JD Dart Offline OP
JD Dart  Offline OP
WA
I don't think it should be an issue with the B1 original heads takes so long to drain back there bathed in oil. My only concern would be for the pushrods. World block puts in .040 restrictor per Mopar instructions according to their website.
