Re: Well, I tried to put my motor in today
[Re: Dartthunder340]
#890698
12/29/10 01:44 AM
12/29/10 01:44 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I wonder if you could just cut a hole where your red circle was in the picture, then put whatever diameter pipe to run the oil line through the area and weld around it all, I don't know if that would be more of a hassle or if I even explained it enough to understand. Just trying to offer a suggestion.
If you'll study the pic above the one with the circle where I have the motor sitting on the mounts I think you'll see that my "circle" isn't quite to scale and that most of the fitting/line routing would be where the motor mount now resides.
#890700
12/29/10 01:54 AM
12/29/10 01:54 AM
WILD BILL
BROOK PARK, OH
At this point hosre racing is looking mighty tempting
[Re: WILD BILL]
#890701
12/29/10 03:31 AM
12/29/10 03:31 AM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
I put one of Any F's motor plates in my ride and it cured all my clearance issues. I then took a torch to all the extra mount supports and had all the room in the world for the external oil pump & lines. Also helps strengthen the frame and with the And f plate you dont have to worry about the engine shift foreward or back its 3/8'' thick and solid. Also inspires you to lighten your kframe. I'm sure road hazzard can help with the extra w/p gaskets
Founder and CEO of the Central Valley Mopar Drag Pack
[Re: mikeysmopars]
#890704
12/29/10 11:59 AM
12/29/10 11:59 AM
WILD BILL
BROOK PARK, OH
I thought you had to run a limiter with any type of motor palte
[Re: WILD BILL]
#890705
12/29/10 12:41 PM
12/29/10 12:41 PM
mikeysmopars
fresno ca
I'm sorry wild bill. That plate isn't 3/8'' its 3/4''
[Re: WILD BILL]
#890706
12/29/10 02:52 PM
12/29/10 02:52 PM
Posts: 2,379 MD
Kevins493
MD
Limiters are easy to make though. Took maybe a day for mine and we had to take it to a friend to get it welded because I don't have a tig and we made it in CM.
[Re: ro23car]
#890708
12/29/10 03:08 PM
12/29/10 03:08 PM
WILD BILL
BROOK PARK, OH
on my pump cover 1 line comes out the front. the other comes out the back. if you want pics lemme know.
Is it in a stock K frame using factory mounts and steering?
[Re: WILD BILL]
#890712
12/29/10 03:26 PM
12/29/10 03:26 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You should... a vertical plate doesnt do much for holding a fore and aft load(it still bows and if it moves enought you push the drive shaft into the trans... and you dont need that
