Page 3 of 5 1 2 3 4 5
Re: Well, I tried to put my motor in today [Re: Dartthunder340] #890698
12/29/10 01:44 AM
12/29/10 01:44 AM
BROOK PARK, OH
WILD BILL Offline OP
BROOK PARK, OH
I wonder if you could just cut a hole where your red circle was in the picture, then put whatever diameter pipe to run the oil line through the area and weld around it all, I don't know if that would be more of a hassle or if I even explained it enough to understand. Just trying to offer a suggestion.
If you'll study the pic above the one with the circle where I have the motor sitting on the mounts I think you'll see that my "circle" isn't quite to scale and that most of the fitting/line routing would be where the motor mount now resides.
Re: Well, I tried to put my motor in today [Re: WILD BILL] #890699
12/29/10 01:51 AM
12/29/10 01:51 AM
Colorado Springs, Colorado
Dartthunder340 Offline
Bummer Wild Bill. I've got great plans for a horse...
Better get inside Ma. Looks like a storm's comin'.
Re: Well, I tried to put my motor in today [Re: Dartthunder340] #890700
12/29/10 01:54 AM
12/29/10 01:54 AM
BROOK PARK, OH
BROOK PARK, OH
At this point hosre racing is looking mighty tempting
Re: Well, I tried to put my motor in today [Re: WILD BILL] #890701
12/29/10 03:31 AM
12/29/10 03:31 AM
fresno ca
mikeysmopars Offline
fresno ca
I put one of Any F's motor plates in my ride and it cured all my clearance issues. I then took a torch to all the extra mount supports and had all the room in the world for the external oil pump & lines.
Also helps strengthen the frame and with the And f plate you dont have to worry about the engine shift foreward or back its 3/8'' thick and solid.
Also inspires you to lighten your kframe.
I'm sure road hazzard can help with the extra w/p gaskets
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Well, I tried to put my motor in today [Re: mikeysmopars] #890702
12/29/10 03:42 AM
12/29/10 03:42 AM
The Wet Coast, Canada
megajoltman Offline
megajoltman  Offline
I went the motor plate route with mine because of that little problem....
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
Re: Well, I tried to put my motor in today [Re: megajoltman] #890703
12/29/10 06:01 AM
12/29/10 06:01 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
this may sound stupid but one of the reasons I went with the world block is cause the front oiling option in the block to eliminate this issues! I have no motor plate either! here is how my mount is if it helps you in any way!(a body) someday I may switch to a motorplate, who knows!
Mopar Performance
Re: Well, I tried to put my motor in today [Re: mikeysmopars] #890704
12/29/10 11:59 AM
12/29/10 11:59 AM
BROOK PARK, OH
BROOK PARK, OH
I thought you had to run a limiter with any type of motor palte
Re: Well, I tried to put my motor in today [Re: WILD BILL] #890705
12/29/10 12:41 PM
12/29/10 12:41 PM
fresno ca
fresno ca
I'm sorry wild bill. That plate isn't 3/8'' its 3/4''
Re: Well, I tried to put my motor in today [Re: WILD BILL] #890706
12/29/10 02:52 PM
12/29/10 02:52 PM
MD
Kevins493 Offline
Kevins493  Offline
MD
Limiters are easy to make though. Took maybe a day for mine and we had to take it to a friend to get it welded because I don't have a tig and we made it in CM.
Re: Well, I tried to put my motor in today [Re: Kevins493] #890707
12/29/10 03:00 PM
12/29/10 03:00 PM
s e mich
ro23car Offline
ro23car  Offline
s e mich
on my pump cover 1 line comes out the front. the other comes out the back. if you want pics lemme know.
Re: Well, I tried to put my motor in today [Re: ro23car] #890708
12/29/10 03:08 PM
12/29/10 03:08 PM
BROOK PARK, OH
BROOK PARK, OH
Is it in a stock K frame using factory mounts and steering?
Re: Well, I tried to put my motor in today [Re: Kevins493] #890709
12/29/10 03:09 PM
12/29/10 03:09 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
I thought dual lines take a long time to build oil pressure.
to me thats not good.
Re: Well, I tried to put my motor in today [Re: mikeysmopars] #890710
12/29/10 03:15 PM
12/29/10 03:15 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I've got the same Andtf plate in both of my cars and they look the same as yours, there 3/8" thick.
Re: Well, I tried to put my motor in today [Re: 70blackfish] #890711
12/29/10 03:19 PM
12/29/10 03:19 PM
alaska,usa
9
9secondsatellite Offline
alaska,usa
do you have a 60 degree fitting you can try in that area? i had the same problem and with a very small bit of clearencing was able to make a 60 degree swivel fit with no problem. my line fit through the opening between the k-member and the gear box mount.
Re: Well, I tried to put my motor in today [Re: WILD BILL] #890712
12/29/10 03:26 PM
12/29/10 03:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You should... a vertical plate doesnt do much for
holding a fore and aft load(it still bows and if it
moves enought you push the drive shaft into the trans...
and you dont need that
Re: Well, I tried to put my motor in today [Re: WILD BILL] #890713
12/29/10 03:52 PM
12/29/10 03:52 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
mine
Re: Well, I tried to put my motor in today [Re: Dodgem] #890714
12/29/10 03:55 PM
12/29/10 03:55 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
next
Re: Well, I tried to put my motor in today [Re: Dodgem] #890715
12/29/10 03:56 PM
12/29/10 03:56 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
where
Re: Well, I tried to put my motor in today [Re: Dodgem] #890716
12/29/10 03:57 PM
12/29/10 03:57 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
next one
Re: Well, I tried to put my motor in today [Re: Dodgem] #890717
12/29/10 03:58 PM
12/29/10 03:58 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
definately easier to put the pump on last.
