Page 1 of 5 1 2 3 4 5
Well, I tried to put my motor in today #890658
12/28/10 09:41 PM
12/28/10 09:41 PM
BROOK PARK, OH
WILD BILL Offline OP
BROOK PARK, OH
However, ran into a slight snag with the new oil pump and lines hitting the K frame.
I cut as much off as I dared trying to gain clearance for the side inlet
But while it goes in there is no room for the fitting or for the line to reach the the pan.
It looks like I might be able to access the rear port if I was to get rid of the stock mounts and do a little cutting.
The rear port seems to line up where the red circle is
My thoughts were if I cut the mount pads off the k frame where the red lines are
And then weld in a piece of steel to reinforce the gear box mount where I have these arrows
If I do all that it looks like I'll gain the room I need to run this system but then I'll be forced to run a motor plate.
Does anyone see a problem with this or maybe see another possible solution that I haven't thought of yet?
Re: Well, I tried to put my motor in today [Re: WILD BILL] #890659
12/28/10 09:47 PM
12/28/10 09:47 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
my pump is like that.i had to run the oil line to the front after i ground the part of the bracket in front all the way to the k frame.
Re: Well, I tried to put my motor in today [Re: WILD BILL] #890660
12/28/10 09:49 PM
12/28/10 09:49 PM
okla.
sam64 Offline
sam64  Offline
okla.
the steering box needs a pretty good brace,i don't know if you are going to get enough bracing in there with the oil line.i would be looking into a street L pipe fitting,then loop line around.
Re: Well, I tried to put my motor in today [Re: blownzoom440] #890661
12/28/10 09:50 PM
12/28/10 09:50 PM
BROOK PARK, OH
BROOK PARK, OH
Please tell me you have some pics of that Mike?
Re: Well, I tried to put my motor in today [Re: WILD BILL] #890662
12/28/10 09:53 PM
12/28/10 09:53 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
I had to do the same to fit the milidon oilpump with duel oil lines
now its a single oil line
now that the moter is out reinforce the steering bracket and box it up
my manual streering box was moving the bracet over when the car was on the ground
theres a lot of strease (sp) there
1.39 9.85 - 137 mph
Re: Well, I tried to put my motor in today [Re: Ari440] #890663
12/28/10 10:05 PM
12/28/10 10:05 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
? might be a good time to call Bondo Bob....maybe one of his K frames ??
Re: Well, I tried to put my motor in today [Re: 69CHARGERMD] #890664
12/28/10 10:10 PM
12/28/10 10:10 PM
BROOK PARK, OH
BROOK PARK, OH
You buyin
Re: Well, I tried to put my motor in today [Re: WILD BILL] #890665
12/28/10 10:13 PM
12/28/10 10:13 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Bill...why not just make a motor plate?...
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Well, I tried to put my motor in today [Re: 69CHARGERMD] #890666
12/28/10 10:18 PM
12/28/10 10:18 PM
UK
602heavy Offline
602heavy  Offline
UK
Had the same issue on a 68 charger , ended up fitting a sandwhich plate between block & oil pump , no drain back issues to worry about. , spun this motor to 7500 (megablock).
Re: Well, I tried to put my motor in today [Re: WILD BILL] #890667
12/28/10 10:20 PM
12/28/10 10:20 PM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
We used the side port on mine and had to trim the k-frame a bit but it clears fine. Routed the lines over top the mount and steering box.
You will need a 90* elbow off the back of the pump to make this work.
Ron
Re: Well, I tried to put my motor in today [Re: WILD BILL] #890668
12/28/10 10:21 PM
12/28/10 10:21 PM
ELYRIA,OH
ELYRIA,OH
i looped my oil line around the front of the k frame and down to the pan but you vould drill/cut a hole to make the line shorter.you may be able to go streight down with the line thru the k also but with both you must get the line tight on the pump before installing the engine as you will not get the pump out or tighten the line with any ease.i deal with it only taking the engine out every few yrs.i hope it will be that long for you. here is how my line is at pan level.
Re: Well, I tried to put my motor in today [Re: firefighter3931] #890669
12/28/10 10:22 PM
12/28/10 10:22 PM
Ontario,Canada
Ontario,Canada
Another view with the factory mount & brackets bolted on the motor.
Ron
Re: Well, I tried to put my motor in today [Re: blownzoom440] #890670
12/28/10 10:27 PM
12/28/10 10:27 PM
BROOK PARK, OH
BROOK PARK, OH
Earlier K frames must have more room there
I thought about a 90* fitting but can't see it fitting in there.
Re: Well, I tried to put my motor in today [Re: firefighter3931] #890671
12/28/10 10:30 PM
12/28/10 10:30 PM
BROOK PARK, OH
BROOK PARK, OH
Ron
Do you have a pic of it in the car?
DO they make a 90* O ring fitting or did you piece something together?
Re: Well, I tried to put my motor in today [Re: WILD BILL] #890672
12/28/10 10:36 PM
12/28/10 10:36 PM
Ontario,Canada
Ontario,Canada
Bill, I have the same k-frame as you.
It will fit but you have to grind some scallops out of that bracing. I'm even running power steering on mine....it's tight but it does fit.
Ron
Re: Well, I tried to put my motor in today [Re: firefighter3931] #890673
12/28/10 10:39 PM
12/28/10 10:39 PM
BROOK PARK, OH
BROOK PARK, OH
Ron
What fitting did you use in the pump cover?
Re: Well, I tried to put my motor in today [Re: WILD BILL] #890674
12/28/10 10:41 PM
12/28/10 10:41 PM
Ontario,Canada
Ontario,Canada
Ron
Dwayne put the oiling system together so i'm not sure exactly what he used on the back of the pump ?
I don't have any pics of it in the car unfortunately. It took several trial fits to get it just right. I'm using factory rubber biscuit mounts that have been re-inforced so i don't know if that makes a difference or not.
Ron
Re: Well, I tried to put my motor in today [Re: WILD BILL] #890675
12/28/10 10:43 PM
12/28/10 10:43 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Bill, it's time for one of Andy's 3/8" motor plates
A plate makes life much easier and less stress on the block IMO
I run the dual line system if you need some pics I'll take some even though it's an A Body and cold out
Re: Well, I tried to put my motor in today [Re: roadhazard] #890676
12/28/10 10:50 PM
12/28/10 10:50 PM
BROOK PARK, OH
BROOK PARK, OH
Would this be the right one?
http://www.summitracing.com/parts/EAR-949012ERL/
Is the dimensions they list for "fitting size 2" the same as a -12?
Re: Well, I tried to put my motor in today [Re: roadhazard] #890677
12/28/10 10:51 PM
12/28/10 10:51 PM
BROOK PARK, OH
BROOK PARK, OH
I would need another pair of pump gaskets then
