Cam Duration split for 10:1 small valve 383? #890624
12/28/10 09:07 PM
12/28/10 09:07 PM
RoadRaceDart Offline OP
Working on cam specs for a 10:1 compression (checked this so it really is 10:1) 383 with 516 heads with the 2.08/1.60" valves. Car has a Performer RPM intake and headers. I know the LCA and overlap I want. All I want to know is single pattern or dual and if dual what the duration difference between intake and exhaust should be. Thanks!
Joshua
Re: Cam Duration split for 10:1 small valve 383? [Re: RoadRaceDart] #890625
12/28/10 09:26 PM
12/28/10 09:26 PM
Milwaukee, WI
Prince_Valiant Offline
Milwaukee, WI
What kind of car is it going in? What gears? Trans? Purpose?
With older heads I do like split duration cams...you'll usually see a 8-10 degree duration split in most off-the-shelf cams.
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph
1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD)
1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD)
1989 Shelby CSX #500/500
Re: Cam Duration split for 10:1 small valve 383? [Re: Prince_Valiant] #890626
12/28/10 09:43 PM
12/28/10 09:43 PM
The duration split should be almost wholly dependent upon the intake to exhaust flow ratio after the compression ratio, intake and exhaust systems are accounted for. I know all the other parameters for my cam which is why I asked this one question. I need expertise from someone who has worked with these heads.
Joshua
Re: Cam Duration split for 10:1 small valve 383? [Re: RoadRaceDart] #890627
12/29/10 01:18 AM
12/29/10 01:18 AM
Milwaukee, WI
Milwaukee, WI
Given that you seem to know what you want, look up the data you want here...or better yet, get your heads flow tested and figure it out.
Re: Cam Duration split for 10:1 small valve 383? [Re: Prince_Valiant] #890628
12/29/10 01:29 AM
12/29/10 01:29 AM
IN
ahy Offline
ahy  Offline
IN
Headers or manifolds? Free flowing headers favor less or no split. Manifolds probably like the split.
Re: Cam Duration split for 10:1 small valve 383? [Re: ahy] #890629
12/29/10 01:45 AM
12/29/10 01:45 AM
Call the experts, Hughes, Comp Cams, etc.
