Engine Leveler
#890185
12/28/10 02:21 PM
12/28/10 02:21 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Do any of you use this tool? The chains are too darn short to reach the side of the heads. The only way I see it working is to remove the heads and bolt it to the block but I don't really want to do that.
I can either lenghten the chains or pay $10 more for one at another store that has longer chains. Just figured I'd ask what you guys are bolting these to. I will not use an intake plate even though some have good luck with them. I've always bolted a chain to the back of the driver's side head and to the front of the passenger side head but the motor always hangs all crooked, figured I'd try one of these.
Re: Engine Leveler
[Re: ProSport]
#890186
12/28/10 02:24 PM
12/28/10 02:24 PM
Posts: 6,295 U.S.
moparniac
U.S.
why not just use an intake plate?
Mopar Performance
Re: Engine Leveler
[Re: moparniac]
#890187
12/28/10 02:29 PM
12/28/10 02:29 PM
Posts: 462 Stockholm, Sweden
fed
Stockholm, Sweden
Im using an homemade intake plate on my filled 440. Works perfekt!
Cuda, -70 Valiant-65 AWB, Valiant Signet200 -65 Topchopped dragcar. Topolino Fuel Altered. NostalgiaFED Sold, SuperComp Bantam Altered, Sold Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
Re: Engine Leveler
[Re: ProSport]
#890192
12/28/10 03:29 PM
12/28/10 03:29 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I use it ALL the time... I pull the engine and trans together and that makes it real easy... I made mine but its the same thing... you would be better off paying the extra 10 bucks to get the longer chains... by the time you get the chain and chain couplers you would have close to 10 bucks and you still would have gas money... mine is almost as long as a small block.... I have 2 holes in the front motor plate and 2 in the mid plate just for this to bolt to
Re: Engine Leveler
[Re: dakster]
#890193
12/28/10 03:36 PM
12/28/10 03:36 PM
Posts: 9,336 South-Central (Sebring), FL
Commando1
I use the intake bolts that goes in the heads and shorten the chain as much as I can.
Ditto!
No matter what you do, get rid of that hand crank and weld on a large hex nut that you can drive with an air ratchet!
Re: Engine Leveler
[Re: justinp61]
#890196
12/28/10 04:25 PM
12/28/10 04:25 PM
Posts: 5,080 organ
maximum entropy
organ
i've been using harbor fright's "top of the line" (pause for hysterical laughter) leveler, and after disassembling it and lubing, adding thrust washers, and detailing, it works very well. an extremely robust piece that needed a little attention. i think the capacity is 4000 pounds? chain without loops. very heavy chain that i bolt to the intake.
Re: Engine Leveler
[Re: fourgearsavoy]
#890202
12/29/10 02:37 AM
12/29/10 02:37 AM
ProSport
Akron, Ohio
Hey be quiet Gus! But can you get me a part number for that oil pan bolt. Jeff, I'm keeping the motor/tranny but the car is getting traded for another rolling chassis. I'm not gonna get into any details til it's all said and done and the car is in my garage.
