Welding on quarter panels #890124
12/28/10 01:57 PM
12/28/10 01:57 PM
USA
Hooligan Offline OP
Hooligan  Offline OP
USA
I just welded a pair of AMD quarter panels to my '69 Coronet. I spot welded the part of the quarter that meets the rocker below the corner of the doors. Should I also run a full bead of weld along the edge of the new querter panel where it lays on top of the rocker where the factory had previously covered it with lead? I can't remember how it was when I removed them. Thax, Steve
Re: Welding on quarter panels [Re: Hooligan] #890125
12/28/10 03:25 PM
12/28/10 03:25 PM
Minn
SportF Offline
SportF  Offline
Minn
I'm not sure what the factory did, but I do know that if you have a seam that is to be covered with bondo you have to weld it 100% or it will crack and show. Good luck!
Re: Welding on quarter panels [Re: SportF] #890126
12/28/10 04:41 PM
12/28/10 04:41 PM
near Port Huron, MI
Paul Offline
Paul  Offline
near Port Huron, MI
They were spot welded then leaded at the factory. I think it makes sense to weld the entire seam in this case and coat with a quality filler rather than lead. The solid weld will help prevent moisture from getting between the panel and filler and hopefully somewhat reduce body flex. Although if if it does flexes, the filler will probably crack.
Maybe a bump shop pro will chime in and give us their opinion.
Re: Welding on quarter panels [Re: Paul] #890127
12/28/10 06:30 PM
12/28/10 06:30 PM
Minn
SportF Offline
SportF  Offline
Minn
I'm no pro, but I've done a fair amount of body work over the years. Never have had any cracks if its welded 100%, and I've stressed out more than a couple of these cars on the track.
Re: Welding on quarter panels [Re: SportF] #890128
12/28/10 08:40 PM
12/28/10 08:40 PM
ohio
jaycuda Offline
jaycuda  Offline
ohio
I do alot of them and like alot of areas the rockers being one of them the factory mig welded along with spot welds. You see it alot at the sail panel (roof to 1/4) rear floor pan centers just to name a few. I spot weld then seam weld long beads just to be over kill at the rocker and it can be without solid welds as long as you weld around 75% of the seam . I never had problems with body work cracking and have done them like that with no issues for years. See sheet metal being undrill and re-welded on my video's section of my web site www.Jaycuda.com I put alot of cars in metal work on the site.
Re: Welding on quarter panels [Re: jaycuda] #890129
12/28/10 10:59 PM
12/28/10 10:59 PM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
I agree with the above. I like to weld those areas solid, just keep the heat down so as not to buckle the area as you do so (especially the roof).
We lead our joints, but you can use a good quality filler & shouldn't have any problems.
Re: Welding on quarter panels [Re: Paul Jacobs] #890130
12/29/10 11:10 AM
12/29/10 11:10 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
We lead our joints...
When I become a billionaire. I'm sending my car to you guys.
Re: Welding on quarter panels [Re: Commando1] #890131
12/29/10 09:44 PM
12/29/10 09:44 PM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
I understand, but we can do the 5 years resto plan too. I'm not weathy enough myself to have my car done at someone elses shop!
Take your time & you will do fine, and you can hold your head high that you did it all yourself.
Thanks for the confidence.
Paul
Re: Welding on quarter panels [Re: Paul Jacobs] #890132
12/30/10 10:25 AM
12/30/10 10:25 AM
Commando1 Offline
Commando1  Offline
Paul
Actually, it seems my current car is on the 20 year plan. Unfortunately I'm 61.
This is why I stay glued to forums and topics like this. Every time it comes to the next step in what I have to do, I think about what has been posted in the past and gives me the courage to try something I never did before. Many, many people here have given me some top-notch advice and has allowed me to accomplish some (to me, anyway) tough jobs.
Yah, if and when that time comes, I'm going to try leading, now.
Re: Welding on quarter panels [Re: Commando1] #890133
12/30/10 11:52 AM
12/30/10 11:52 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Mr. Jaycuda, What do you make your spot welds with? Saw the back of the green hemi car they look very nice.
Re: Welding on quarter panels [Re: scatpacktom] #890134
12/31/10 12:43 AM
12/31/10 12:43 AM
ohio
jaycuda Offline
jaycuda  Offline
ohio
I will take some pix of the unit and post them along with model info. We upgraded this spring to the water cooled machine. Like most of the bigger units it has a dubble side head with an assortment of changable weld tongs for different reach areas and the single sided gun for some of the areas that are to hard to reach. To get the spot welds to look correct size per area I custome grind the electrode tip or in some cases turn the setting current, thickness,# of sheets of metal, head type exc It has lots of tunning on the panel bord and this helps tune the burn look as well as get the weld penetration needed.
Re: Welding on quarter panels [Re: jaycuda] #890135
12/31/10 11:26 AM
12/31/10 11:26 AM
ohio
jaycuda Offline
jaycuda  Offline
ohio
Spot welder pix
Re: Welding on quarter panels [Re: jaycuda] #890136
12/31/10 11:30 AM
12/31/10 11:30 AM
ohio
jaycuda Offline
jaycuda  Offline
ohio
Single side pic and one of the longer reach tong sets. The tongs have removable tips so I grind them for larger or smaller spot weld look. The single sided is controled more by setting and being sure the ground is on the correct piece of sheet metal on the correct side. That is everything on sinle sided welding or you will have what most people talk about as ending up with, a weld that will not hold or look correct. Hope this will give everyone a better idea of the unit Jay. www.jaycuda.com
Re: Welding on quarter panels [Re: jaycuda] #890137
12/31/10 11:32 AM
12/31/10 11:32 AM
ohio
jaycuda Offline
jaycuda  Offline
ohio
last pic
Re: Welding on quarter panels [Re: jaycuda] #890138
12/31/10 12:20 PM
12/31/10 12:20 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Thanks Jaycuda That thing does a nice job
Re: Welding on quarter panels [Re: scatpacktom] #890139
01/01/11 01:01 AM
01/01/11 01:01 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
My car has the same cracking too. The last guy who owned it did the body work and filled in the seams on the trunk panel behind the rear window and the seams where the rockers meet the quarters. Of course they cracked, they always do. Well I could see it holding up just fine if they were welded but seems that never occurs to these guys.
Re: Welding on quarter panels [Re: jaycuda] #890140
01/01/11 03:15 PM
01/01/11 03:15 PM
Fremont, CA.
Topcat Offline
Topcat  Offline
Fremont, CA.
Quoted from Resto Rick's website:
The other place I insist on using lead is on the roof seams and rocker panel to quarter joints. These seams are vulnerable to “telegraphing”. A condition where the seam becomes visible in the hot sun. It’s caused by differences in expansion of the different metal thicknesses and stress differences of the panels. Use of any plastic based filler will not stop it!...This includes All Metal, Metal-To-Metal, Tiger Hair, DuraGlas, any ‘glass strand fillers, etc. The only cure I’ve had success with is to lead the seam.
I leaded my quarter panels on. While some believe lead work isn't a necessity; I've been thru the band aid effect before when my car was black. The lead kits today are high solder content making it a little easier to apply. Here's a pic where I leaded the lower rocker. Almost upside down when I did it.
Re: Welding on quarter panels [Re: Topcat] #890141
01/01/11 06:09 PM
01/01/11 06:09 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
I had never heard of telegraphing up until about 2 weeks ago watching an episode of Stacy Davids Gearz. He is a tig weld guy because it minimizes this. Very interesting as I thought mig welded and bondoed up was as good as it got.
Keep old mopars alive.
Re: Welding on quarter panels [Re: 2boltmain] #890142
01/01/11 09:00 PM
01/01/11 09:00 PM
Fremont, CA.
Topcat Offline
Topcat  Offline
Fremont, CA.
Doing leadwork isn't as hard as some imagine. With the higer amount of solder now, it's not as much of a health risk either. I would recommend doing it outside if possible. E bodies have such a large visible sail panel; I would advise leadwork over filler based on my past experiences of telegraphing.
