...speaking of dynos, going Thursday FULL RESULTS
#890024
12/28/10 04:24 AM
12/28/10 04:24 AM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
I'm headed over to Bob Lambeck's place on Thursday to dyno-tune the 496 after pulling it post Silver State Classic oil-starvation due to an incorrectly set adjustable bypass. I replaced all the bearings after I found some mild signs of starvation. I also found I had insufficient chamfer clearance and most of the bearingsd had a tiny ring of copper on the outside from rubbing the fat radius. New narrow bearings with hand-clearanced edges solved that problem.
Last time I had it dyno'd was when I built it in a mad rush to make it to MATS after killing the crank at March Meet. There was no time to tune, just a break in with a bad carb, then one pull with the replacement carb. We knew it was pig rich, but had to go with it for the sake of time. After pulling 8 jet sizes out it picked up over 3 tenths.
What do you think it will make now? I won't spoil your guesses with the old numbers unless requested.
440 +.040, stroked to 496 with a 440source 4.15 kit 10.44:1 compression, 91 octane pump gas Holley 1000HP MP M1 single plane intake .597/.607 257°/259° @.050 sold flat tappet Eddie RPM, unported, port machining transitions smoothed/gasket matched 2 1/8"/3.5" TTI headers MP distributor, 35° total
ETA: Engine dyno, not chassis
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: ...speaking of dynos... going on Thursday
[Re: moparniac]
#890027
12/28/10 11:02 AM
12/28/10 11:02 AM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
570...562... WOW! I will be pretty impressed if that motor makes close to 700 hp at the crank!!! I will guess 450 rwhp
[Re: 2QUICK4U]
#890029
12/28/10 12:57 PM
12/28/10 12:57 PM
67Charger
Erda, UT
should have specified "engine dyno"
[Re: Quicksilver440]
#890033
12/30/10 10:41 AM
12/30/10 10:41 AM
67Charger
Erda, UT
'tis still the wee morning hours over here, and I'm loading the engine up to go. Any last guesses?
#890038
12/31/10 02:15 AM
12/31/10 02:15 AM
67Charger
Erda, UT
609.1 @ 5500 647.9 @ 4400
I'll post the average numbers in a few minutes, but it is a big, fat, flat power curve.
#890040
12/31/10 04:17 AM
12/31/10 04:17 AM
Posts: 397 California, USA
Phil Saran
California, USA
Can I ask ball park the cost of running your engine on Lambecks dyno?? I assume 3 pulls.
Phil Saran
Parker, Colorado
[Re: Phil Saran]
#890041
12/31/10 01:17 PM
12/31/10 01:17 PM
67Charger
Erda, UT
Cost: $550 for 9 hours and 21 pulls.
Correction: Final was 609.1 @ 5700 and 647.7 @ 4500 over 600 HP from 5200 - 5700 over 600 ft.lb. from 3700 - 5200
First run was 575/604, and every run we would change 1 thing.
On 91 octane, the engine made more power each time we took timing away. It runs best at 30° total, not the 36 I was previously running.
The carb ended up wanting 7 more sizes on the primary and one less on the secondary for a final of 84/88.
Swapping the HS air bleeds from 25 to 29 gave me about 5 on the top and got rid of a rich condition past 5000.
Adding a 1" 4 hole over a 1 inch open was worth 13 HP and 9 ft.lb. over no spacers at all.
My 14x3 paper air filter cost me 10HP over no cleaner at all, a 14x3 4 ply K&N only cost me 2HP.
There is a slight surge over 5500 that couldn't be tuned out since it is a result of not enough exhaust duration to compensate for my tiny ports. Only fixed by porting or a new cam.
Further pulls revealed the engine was still running well past 6600, but power was down to 552 out there.
I'll post copied of the dyno sheets in a little while.
[Re: 67Charger]
#890042
12/31/10 01:27 PM
12/31/10 01:27 PM
Posts: 9,924 Weddington, N.C.
Streetwize
Weddington, N.C.
Nice!!! Saw it late but I was gonna guess 600/600....on paper it looked very close to my old 508 Stage V/Hyd roller combo that I figued to be in the ~620 range. Guys looking for a 'default' 500" 600/600 combo need look no further File it inthe tech archives!!
[Re: 67Charger]
#890043
12/31/10 01:35 PM
12/31/10 01:35 PM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
1.22HP per cube..
Are you happy?
