Re: ...speaking of dynos... going on Thursday
[Re: 67Charger]
#890045
12/31/10 01:40 PM
12/31/10 01:40 PM
Thumperdart
State of confusion
Cost: $550 for 9 hours and 21 pulls.
Correction: Final was 609.1 @ 5700 and 647.7 @ 4500 over 600 HP from 5200 - 5700 over 600 ft.lb. from 3700 - 5200
First run was 575/604, and every run we would change 1 thing.
On 91 octane, the engine made more power each time we took timing away. It runs best at 30° total, not the 36 I was previously running.
The carb ended up wanting 7 more sizes on the primary and one less on the secondary for a final of 84/88.
Swapping the HS air bleeds from 25 to 29 gave me about 5 on the top and got rid of a rich condition past 5000.
Adding a 1" 4 hole over a 1 inch open was worth 13 HP and 9 ft.lb. over no spacers at all.
My 14x3 paper air filter cost me 10HP over no cleaner at all, a 14x3 4 ply K&N only cost me 2HP.
There is a slight surge over 5500 that couldn't be tuned out since it is a result of not enough exhaust duration to compensate for my tiny ports. Only fixed by porting or a new cam.
Further pulls revealed the engine was still running well past 6600, but power was down to 552 out there.
I'll post copied of the dyno sheets in a little while.
As many have stated in the past, some of these tweeks MAY or may not make the car go down the track quicker. After my chassis dyno, I needed more jet to get best et`s but hey, good numbers and good luck at the track.
[Re: 67Charger]
#890046
12/31/10 02:00 PM
12/31/10 02:00 PM
BradH
How exactly did this "surge" manifest itself? Got any dyno printouts that show the air flow data along w/ the full pull's torque & HP #s? How high did you spin it?
[Re: BradH]
#890047
12/31/10 02:17 PM
12/31/10 02:17 PM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
Thanks all,
The surge was very audible, and the a/f ratio oscilated a fair bit. Slight variation on the otherwise smooth power curve. No intake flow data. After inspecting my cam specs we both agreed on the lack of exhaust duration. Some tunes had a more or less pronounced effect, but it was never gone.
As a rule we shot for the best averages between 4100 and 6200, which happened to be the same run as the best peaks. Some changes did give better peaks than previous runs but losses on the averages.
My scanner is on the fritz, so the result sheets will have to wait until this evening.
On the whole, I am very happy with the results.
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
[Re: 67Charger]
#890048
12/31/10 02:35 PM
12/31/10 02:35 PM
Posts: 2,937 A shed in England
Tig
A shed in England
Great info Were the above numbers @ peak? Thanks.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: 67Charger]
#890050
12/31/10 04:13 PM
12/31/10 04:13 PM
Posts: 43,352 Bend,OR USA
Cab_Burge
My 518 had a small miss or surge bewteen 5200 and 5600 RPM the last time it was on the dyno It has never had that before with the eddy heads and any intake and carbs I have tested The last dyno session I had the CNC ported 440-1 heads on it with the same cam as before, 260 @ .050 intake side and 266 @ .050 on the exhaust using 1.64 ratio rockers I have since switch the 440-1 heads to the 528 bracket motor and put the SR heads on the 518 motor, I'll dyno test the 528 motor with the -1 heads on it and see if it surges or misses like the 518 did I did have a set of dyno headers that where a little smaller on the exhaust ports than the heads are I do have a seto hedman heades made for the Indy -1 keads that I will use on the next dyno tets, they where in the car nad I was to lazy to remove them for that dyno test, stupid me I'll post the results, probally retest it late in January, weather, time and money allowing don't we love dyno testing Thumper is correct as far as what works best on the dyno, engine or chassis dynos, doesn't always get the best results in the car at the track or on the road My message is to test, test and test some more once the motor is in the car and being raced Congratulations on the results
[Re: 67Charger]
#890052
12/31/10 05:12 PM
12/31/10 05:12 PM
BradH
Not being there, this is kind of a s.w.a.g., but that sounds more like you got into valve train instability from about 5500 on up, not an indication of insufficient exhaust duration.
It looks like you're running some fairly aggressive solid flat-tappet lobes and those things will start to act up at high(er) RPM w/o a fairly stiff spring load. What sort of springs do you have and what are they set up for closed & open pressures?
I don't know if you can make the same interpetation from A/F ratio fluctuation, but when the measured air flow #s start showing fluctuations above a certain RPM, that can be a sign of the valve train losing control.
[Re: 67Charger]
#890054
12/31/10 06:10 PM
12/31/10 06:10 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Thanks all,
Nice job.... could you change the RPM of the surge or did it start at the same point each run(even with added fuel.... if you couldnt change the rpm I would think valve train also
[Re: BradH]
#890055
12/31/10 06:38 PM
12/31/10 06:38 PM
67Charger
Erda, UT
...that was at each peak. I didn't run the whole chart looking for the biggest difference, but not a bad idea to do.
Are you saying you stacked a 1" tapered over a 1" open? Will that fit under the hood?
Yes, that's what I meant, and no, I have to use my other hood with the scoop.
The springs are COMP 928's or 927's, I'll have to check and get back to you on the number and specs. I never measured the actual installed pressures, just the calculated numbers using my measured heights and the listed specs.
Thanks for posting.
What carb are you running?
Holley 1000HP, List 80513-1
Re: ...speaking of dynos, going Thursday FULL RESULTS
[Re: 67Charger]
#890056
01/01/11 01:12 AM
01/01/11 01:12 AM
Posts: 793 Utah
topbrent
Utah
67Charger: 440 +.040, stroked to 496 with a 440source 4.15 kit 10.44:1 compression, 91 octane pump gas Holley 1000HP MP M1 single plane intake .597/.607 257°/259° @.050 solid flat tappet Eddie RPM heads, unported, port machining transitions smoothed/gasket matched 2 1/8"/3.5" TTI headers MP distributor, 35° total
Final was 609.1 @ 5700 and 647.7 @ 4500 - over 600 HP from 5200 - 5700 - over 600 ft.lb. from 3700 - 5200
Nice results.
- What is the lobe separation on that cam? - Is the cam installed advanced?
[Re: viperblue72]
#890058
01/04/11 06:26 AM
01/04/11 06:26 AM
67Charger
Erda, UT
[Re: BradH]
#890060
01/04/11 01:52 PM
01/04/11 01:52 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
That is sweet!! It gives me a good idea of what my charger makes for power. How much does your car weigh? Is this the same combo as is your signature e.t's? What gear and converter are you running? What 60' times are you running?
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#890061
01/04/11 02:42 PM
01/04/11 02:42 PM
67Charger
Erda, UT
Yes, it is the same setup, but it was pre-tuning. I just picked up 34 HP and 34 ft.lb over those numbers. Car is 4000# with me. 4.10's in a Dana and a 8" PTC stalling at 5000. The numbers: Curves: A/F: not the best, but it made most power and we were out of time. Averaged 13.4, dipped to 12.6 at about 5700. Adding more fuel to the secondaries lost power.
[Re: 67Charger]
#890062
01/04/11 03:10 PM
01/04/11 03:10 PM
dragram440
bigfork mn
Looks like a good combo. A little head work and I bet it would really wake it up. Those Eddy heads obviously work pretty good out of box. It is a similar combo to mine but mine is 12.5-1 comp. solid roller cam stage vi heads worked over m1 intake 3.91 gears 5000 8" coan converter 3800 lbs. no dyno numbers.
67' charger 499 RB
10.57 at 127
