question on spark plug length #889915
12/27/10 09:44 PM
12/27/10 09:44 PM
MD-USA
Dodgeguy101 Offline OP
MD-USA
This may be a silly question and figured someone here may know the answer. I have a clearence issue on #6 plug to header. Champion plugs are 2 inches from the tip, where the wire snaps on and the part that will bottom out in the head. Are there any plugs that will fit Indy heads and are shorter in length? I really didn't want to ding the header tube that bad, and maybe it wouldn't be that bad, but thought if there was a plug that was shorter, it would help.
Re: question on spark plug length [Re: Dodgeguy101] #889916
12/27/10 09:50 PM
12/27/10 09:50 PM
Kirkland, Washington
Pacnorthcuda Offline
Accell makes a shorty plug.
Re: question on spark plug length [Re: Pacnorthcuda] #889917
12/27/10 09:53 PM
12/27/10 09:53 PM
MD-USA
MD-USA
I'll look into that, thanks
Re: question on spark plug length [Re: Dodgeguy101] #889918
12/27/10 10:23 PM
12/27/10 10:23 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
there are a lot of plugs for small engines that use the short top... get one that matches the heat range you need
I am truckless..
