mopar 590 cam.; what CR do i need to go with it? #889830
12/27/10 08:20 PM
12/27/10 08:20 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
what could be the mininum compression for pump gas 93 with this cam? i think im about 10.0CR now. i dont want to detonate with my iron heads but i want a big cam like this! install at 100? i know it would WANT 12.0CR +
other cam choice could be UD 251 578 108. i have a pretty loose 4k stall to use with ethier. i can gear appropriately. im trying to go as fast as possible as cheap as possible! thanks for any inputs!
74 dart sport 440 www.Csucarbs.com
Re: mopar 590 cam.; what CR do i need to go with it? [Re: shoebox] #889831
12/27/10 11:28 PM
12/27/10 11:28 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Id use the smaller cam. As far as whats minimum, as long as you have enough vert, 5000 rpm 10.1 is enough.
Mopar did a comparison on a 8.5 comp 400 motor in the MP engine manuel and it still picked up et over the next smaller purple cam. Not sure of the vert in that test though. mike
Re: mopar 590 cam.; what CR do i need to go with it? [Re: shoebox] #889832
12/27/10 11:50 PM
12/27/10 11:50 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I know of a few iron head 440s that have run high 10 to low 11s
with the 312/590 and roughly 10:1
I'm sure they had 8" converters but, no idea on the stall speed.
B and E bodies too.
Re: mopar 590 cam.; what CR do i need to go with it? [Re: S/ST 3040] #889833
12/28/10 12:26 AM
12/28/10 12:26 AM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
B and E bodies too.
How much rear gear?
Michael
Re: mopar 590 cam.; what CR do i need to go with it? [Re: SILVER67] #889834
12/28/10 12:40 AM
12/28/10 12:40 AM
S/ST 3040 Offline
S/ST 3040  Offline
B and E bodies too.
How much rear gear?
Michael
IIRC, the 69 Charger was 30" tire and 4.56
Re: mopar 590 cam.; what CR do i need to go with it? [Re: S/ST 3040] #889835
12/28/10 12:55 AM
12/28/10 12:55 AM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
Any idea of the 60 foot times? Heavy car?
Re: mopar 590 cam.; what CR do i need to go with it? [Re: SILVER67] #889836
12/28/10 12:59 AM
12/28/10 12:59 AM
ct
jkgtx Offline
jkgtx  Offline
ct
ran one in my car years ago 440 11-1 trws
11.66-11.80s 3850 race weight 1.65-66 60fts
[b] [color:"red"] 67 GTX 440 twin turbo efi 10.72 128 3900lb 3.55
Re: mopar 590 cam.; what CR do i need to go with it? [Re: jkgtx] #889837
12/28/10 01:10 AM
12/28/10 01:10 AM
Kentucky
clovis Offline
clovis  Offline
Kentucky
I have a 10.5:1 906 headed 451 (400) that went 10.75 at 3300lbs with the 590. With more converter(4200) 10.60's were well within reach.
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: mopar 590 cam.; what CR do i need to go with it? [Re: clovis] #889838
12/28/10 01:51 AM
12/28/10 01:51 AM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
between these 2cams in question i mention the 590 because i can get it cheaper than the UD. for the cost of the UD i can get cam and tappets! now i dont know if the newer ones are any good..? do the newer MP cams go flat more so that old ones? i think i read somewhere they changed vendors.. any which way i slice it, ive always liked and wanted to run the 590. hopefully my car will weigh 3400lbs at the line.
440 10.0CR 260cfm 452s,torker,1050,2inch pro parts 4k+stall,3.7x or more gear. we'll see what happens
Re: mopar 590 cam.; what CR do i need to go with it? [Re: shoebox] #889839
12/28/10 02:36 AM
12/28/10 02:36 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Its going to be a pig with that cam. Sure it will run, and probably run decent. But a smaller cam will run and idle much better. That cam was ment for a all out race application. 5K+ converter, race weight car, 12-13:1 compression, and spin the engine 6300+
With a engine and compression near 10:1 you would like the 557 MP cam much better.
Re: mopar 590 cam.; what CR do i need to go with it? [Re: Bob_Coomer] #889840
12/28/10 03:11 AM
12/28/10 03:11 AM
Kentucky
clovis Offline
clovis  Offline
Kentucky
I ran a 10.84 with a Comp 529/543 250/256 108 lsa, with the exact same set-up I ran the 10.75 with the 590. So to Bob's point, it will run quicker & faster but you will have to spin it to do it. I could run 10.80's shifting at 5800 with the old cam, but I had to spin 6600 to get the 10.75. So if you decide to go the 590 route be sure to check your spring pressures, retainers and locks, things like to move around at the higher rpms - dropped valves have a fun rating of -8. BTW I have my old cam for sale if you are interested.
'75 Plymouth Duster
Re: mopar 590 cam.; what CR do i need to go with it? [Re: clovis] #889841
12/28/10 05:25 AM
12/28/10 05:25 AM
K
KOS Offline
KOS  Offline
K
been there..... MP557 way better suited to your application especially if you run through exhaust.
Re: mopar 590 cam.; what CR do i need to go with it? [Re: clovis] #889842
12/28/10 09:46 AM
12/28/10 09:46 AM
gregsdart Offline
gregsdart  Offline
Two buddys of mine have similar results with the 590, both running low elevens with 440 cube motors originally with iron heads, both in 3800 pound cars. Both of these motors had poor quench and 10.5 compression.
Mopar did drag strip tests on all of their cams in the eightys, starting with the smallest cam ,a mp hemi grind and ending with the 590. All testing was done with the same car, a 400 bb motor in a duster. The car picked up over a tenth plus at each cam change with the 590 being the fastest. And that was with a 400 cube low compression motor. For my $$ I would run the 590 and degree it in as early as it likes. I might also try a smaller carb like an 850.
Re: mopar 590 cam.; what CR do i need to go with it? [Re: gregsdart] #889843
12/28/10 10:56 AM
12/28/10 10:56 AM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
CLOVIS i like those numbers! humm lets talk on the side over here... ---->pm
greg i like what your saying! put it in early!!!
KOS i agree completely. the 557 really would be better through full exh and its proven as well. my buddy 383man on here loves it in his 440
Re: mopar 590 cam.; what CR do i need to go with it? [Re: gregsdart] #889844
12/28/10 11:01 AM
12/28/10 11:01 AM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
where could i find that article? id love to read that one!
Re: mopar 590 cam.; what CR do i need to go with it? [Re: shoebox] #889845
12/28/10 11:08 AM
12/28/10 11:08 AM
Burlington,Ont.
77DragracerR/T Offline
Burlington,Ont.
My car is a F-body Dodge 3420# w/driver,408 SB,590 MP cam & lifters with Hughes 1111 springs,Eddy heads,SV intake with 750hp carb pushing the exhaust threw TTI step headers and has run a consistant best of 10.76 as in my vid at the bottom.Also run a 904 trans with 5400 flash 8" TCS converter with 4.30 gears out back.Personally i grabbed the cam because it was cheap and i had lost a Crane cam and needed a quick fix and this was my answer and i like it.
77 Aspen R/T 60'@1.41 10.76 @ 123.26
http://www.youtube.com/watch?v=Eya3Ue8KoZk
Re: mopar 590 cam.; what CR do i need to go with it? [Re: shoebox] #889846
12/28/10 12:28 PM
12/28/10 12:28 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
It's obvious you just want people to tell you it's OK to run the .590, regardless of whether it's the right cam or not.
It's not.
Re: mopar 590 cam.; what CR do i need to go with it? [Re: BradH] #889847
12/28/10 12:46 PM
12/28/10 12:46 PM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
What if you had more converter to make up for a heavier car when using this cam? Such as an 8" or 9"? Like the Turbo Action "J" for instance?
Would that be better for this cam to get the motor in the RPM range where it works well? If that makes sense.
Michael
Re: mopar 590 cam.; what CR do i need to go with it? [Re: Bob_Coomer] #889848
12/28/10 12:53 PM
12/28/10 12:53 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I run an Engle cam real similar to the Ultradyne you're describing in my 451 (assuming 251* @ .050 / .578 lift on 108 cl). My motor is a zero-deck, .044 quench build @ 10.3:1 w/ Stealths and a 35k converter. I feel I have plenty of cam, to the point where I have other areas that need to catch up to the potential of the cam. I don't think you'll be any faster with the .590, but I do think it will be much more difficult to tune & deal with. I think the UD 251 would be MUCH more snappy / crisp down low, and won't give away anything up top, as @ 10:1, you don't have enough compression to make use of the extra duration the .590 is offering. (I guess that was the OP question, wasn't it )
Re: mopar 590 cam.; what CR do i need to go with it? [Re: shoebox] #889849
12/28/10 12:57 PM
12/28/10 12:57 PM
NC
440Jim Offline
440Jim  Offline
NC
440 2295s 070 in the hole
260cfm at 600 452s small valves
Gus,
I have a feeling the 0.590" cam might like more compression ratio than you have. What is the combustion chamber size on your set of 452 heads? They vary a lot.
If the heads are 90cc, 3cc valve reliefs?, and 0.070" pistons down the hole,
your actual CR could be as low as mid 8's. Get all that checked before putting a long duration cam in it.
