Questions on 8 3/4 axle in 64 Polara #889776
12/27/10 07:56 PM
12/27/10 07:56 PM
West Newbury, MA
MOPAR_AMC_FAN Offline OP
West Newbury, MA
From what I've read, the 8 3/4 axleshafts in 64 aren't as strong as the later axleshafts (66-up, I believe). From what I understand, it's almost like the two-piece shafts found on AMCs where the hub is pressed on. I'm not positive about this, but either way, I want to get rid of them. My questions are... Can you just replace the axleshafts with later model units or do you need to swap the whole axle? If you swap in a whole other 8 3/4 from a later model B-body (pre-71), is it a bolt in swap? Any other things I'm missing?
Thanks!
Re: Questions on 8 3/4 axle in 64 Polara [Re: MOPAR_AMC_FAN] #889777
12/27/10 07:58 PM
12/27/10 07:58 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
You must replace the housing/axles. 1966-67 B-body is the assembly you want, and it will be a bolt-in change, track will be slightly (1") narrower.
Wayne
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: Questions on 8 3/4 axle in 64 Polara [Re: MOPAR_AMC_FAN] #889778
12/27/10 08:45 PM
12/27/10 08:45 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Board member Doctor Diff can supply you with flanged axles to fit your current housing, you'll have to scrounge the brake backing plates and drums from a '65 or later.
http://www.doctordiff.com/
Re: Questions on 8 3/4 axle in 64 Polara [Re: 64dodge572] #889779
12/27/10 08:53 PM
12/27/10 08:53 PM
scratchnfotraction Offline
you can get a new set of axle with the modern flange and large brake offset to go in the 8 3/4 housing you have
I used a early A-body keyed axle 8 3/4 housing with a set of moser axles and run large c-body brakes and backing plates 11x2.5 drums 5on4.5 wbp
DrDiff has the axles also
some of the older 8 3/4 chunks are diff on the splines or something but think its the early 57 to early 60 8 3/4 though
shoot dr diff a PM and he can set you straight on the chunk and axle thing
dont swap housing unless its a gotta be thing and save some coin
my axles were about 299$ a set with non adjustable green bearings
now that A-body axle is bolted in the truck to tuck 12" rims in the fenders
Re: Questions on 8 3/4 axle in 64 Polara [Re: scratchnfotraction] #889780
12/27/10 09:18 PM
12/27/10 09:18 PM
okla.
sam64 Offline
sam64  Offline
okla.
get one out of a 65 b body,flanged axles and correct width.i've seen'm as low as 150.00 complete.
Re: Questions on 8 3/4 axle in 64 Polara [Re: sam64] #889781
12/27/10 10:16 PM
12/27/10 10:16 PM
West Newbury, MA
West Newbury, MA
Thanks for the info, guys. I already have a 3.23 sure grip chuck to go in whatever axle, so I just needed to figure out the complete housing vs. just axles issue.
Re: Questions on 8 3/4 axle in 64 Polara [Re: MOPAR_AMC_FAN] #889782
12/27/10 10:27 PM
12/27/10 10:27 PM
At a gas station near you
badblack68 Offline
badblack68  Offline
The non flanged 8 3/4 rears back then were strong enough to hold up in the 13:1 compression manual transmission max wedge cars...
Re: Questions on 8 3/4 axle in 64 Polara [Re: badblack68] #889783
12/27/10 11:27 PM
12/27/10 11:27 PM
Port St Lucie, Florida
towguy76 Offline
towguy76  Offline
how big a pain is it to work on those with the 2 piece axles? I just bought a 56 Dodge 1/2 ton truck and it has the 8 3/4 with the 2 piece axles. According to a previous post, my chuck more than likely has a different spline count so i wont be able to swap axles with out buying a new diff for it. my license plate will probabaly read: MNY PIT (money pit)
Rick
Re: Questions on 8 3/4 axle in 64 Polara [Re: towguy76] #889784
12/28/10 12:16 AM
12/28/10 12:16 AM
wait till you try to remove the hubs
you can losen the nut and drive a few figure 8s and they will break loose some times
most I have seen have to be smoke wrenched off
you need to talk to DrDiff for sure
there is a good write up on the history of the 8 3/4 and talks about the diff in axles and chunks on the 57 up early ones in the archives IIRC
some thing about splines and the thrust block size or what not
Re: Questions on 8 3/4 axle in 64 Polara [Re: scratchnfotraction] #889785
12/28/10 03:38 AM
12/28/10 03:38 AM
towguy76 Offline
towguy76  Offline
Please tell me that the drums come off the hubs since I need to do maintenance on the brakes.
Rick
Re: Questions on 8 3/4 axle in 64 Polara [Re: towguy76] #889786
12/28/10 09:24 AM
12/28/10 09:24 AM
Minn
SportF Offline
SportF  Offline
Minn
The top shoulder of the stud is swedged over and holds the hub to the brake drum. They did this on the front hub as well. This is such a good swedge that if you press the stud out of the hub it can open up the hole as the swedge goes through the hub. In any case, to get the drum-hub assembly off you need a heavy duty puller made especailly for this task. And I have had them where they won't come off, with any method, including cutting the end of the housing and axel off and pounding straight down on the axel stub while heating the hub!
Re: Questions on 8 3/4 axle in 64 Polara [Re: SportF] #889787
12/28/10 01:48 PM
12/28/10 01:48 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
To get the drums off you need the proper puller.I have one that I bought for the 57 and 62.It attaches to the studs and tightens on the big stud that the nut is on.Then there is a handle that you smack with a good sized hammer and they pop off the key way.The 61 we had some moron pressed the drums off the stub.They were so bad that the pedal went up and down when you hit the brakes.Local yard had a set that I bought for it and fixed that problem.I bought my puller from Ebay.Cost me like 35 bucks and was an old I believe Mac.Ive done tons of the rears and never had one that wouldnt come off.My kids 62s were the worst.Took me about and hour to get them off.Rocky
Chrysler Firepower
Re: Questions on 8 3/4 axle in 64 Polara [Re: therocks] #889788
12/28/10 02:04 PM
12/28/10 02:04 PM
West Newbury, MA
West Newbury, MA
I replaced my 2-piece axles with one piece Moser axles in my AMC, but had to have the hubs removed before I sent my stock axles to Moser. I found a shop that would remove the hubs with a BIG press. Sounded like a gunshot when the hubs came off. Yikes!
So, to use the later-than-64 sure grip chuck I have, the easiest way would be to swap to a later axle, preferably a 65?
Re: Questions on 8 3/4 axle in 64 Polara [Re: MOPAR_AMC_FAN] #889789
12/28/10 03:00 PM
12/28/10 03:00 PM
Minn
SportF Offline
SportF  Offline
Minn
Well, that 64 sure grip will work, the splines are all the same, but the sure grip tapered axels are different length than standard axels, and that is a little known fact. But if you make up some axel shims (which is how the axel bearings are pre-loaded) you can make the standard axels work. It will take about .125 to .150 shims each side, if I remmber correctly. If you can get green bearings for those early axels that would take care of that problem, but I don't know if you can. The grease seal for those tapered axels is in-on the backing plate and the bearings are lubed with the 90W in the housing. The 65 and newer have an oil seal a couple of inches down inside the housing and the bearings are lubed greased-or sealed from the outside.
Re: Questions on 8 3/4 axle in 64 Polara [Re: SportF] #889790
12/28/10 03:05 PM
12/28/10 03:05 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
I threw a 68 8 3/4 rear outta a GTX and never had a problem....Bolted right in....
Re: Questions on 8 3/4 axle in 64 Polara [Re: QuickBpBp] #889791
12/28/10 03:56 PM
12/28/10 03:56 PM
West Newbury, MA
West Newbury, MA
The 3.23 sure grip isn't a 64 unit. It's a 4.89 case.
Re: Questions on 8 3/4 axle in 64 Polara [Re: SportF] #889792
12/28/10 04:05 PM
12/28/10 04:05 PM
Rio Linda, CA
Rio Linda, CA
'64 is the first year that didn't used different length axles for SG and non-SG.
The '64 B body rear end dimensions are a holdover from the Forward Look days, wider than any other '62-'70 B body rear.
Re: Questions on 8 3/4 axle in 64 Polara [Re: therocks] #889793
12/28/10 05:11 PM
12/28/10 05:11 PM
towguy76 Offline
towguy76  Offline
Here is my rear drum and 2 piece axle setup. So i gather that in order to inspect and repair the brakes i am going to have to pull the hub off the axleshaft. Since the studs need to be replaced anyway, can i cut out the old ones, remove the drum from the hub, install new modern studs and have the drum removable from the hub for ease of use?
on another note, my front drums use bolts that thread into the hub like a Mercedes instead of studs. They are reverse threads on the driver's side like other pre 70s Mopars though.
Rick
Re: Questions on 8 3/4 axle in 64 Polara [Re: John_Kunkel] #889794
12/28/10 06:27 PM
12/28/10 06:27 PM
Minn
SportF Offline
SportF  Offline
Minn
Certainly didn't know that '64 is the first year of non-different length sure grip axels.
Can you cut off the studs to get the drum off? Yes.......but its not easy. You still will have the swegded shoulder of the stud if you cut it off flush from the outside. You could go in there with a big drill bit to drill some of the swedge, but that is really a drill press operation and you can't do that on the car. I have removed a number of these studs by cutting the head off and pushing it out from the back, but the drum has to be off for that. And, this is a very good grade of stud, so that isn't easy in any case. You really need to get one of the pullers and do it that way, in the end its the right way, and its the easiest way. Good luck to ya!
Re: Questions on 8 3/4 axle in 64 Polara [Re: SportF] #889795
12/28/10 08:49 PM
12/28/10 08:49 PM
6T4 Polara Offline
6T4 Polara  Offline
Drum off use a swegde cutter often found in older auto machine shops.This will save the drum and get new studs pressed in.
John
