Re: 1970 Roadrunner
[Re: Haase27Man]
#889726
12/27/10 07:28 PM
12/27/10 07:28 PM
Posts: 1,222 okla.
okie
okla.
They are pretty much all the same. They will rust out by the back window and then it gets the lower quaters and around the wheel wells. Just check the floors and all the frame work to make sure it is good and not all rusted out. The front seats are pricey but you can find them and all the other parts are easy to find now since they have came out with all the new parts for them. You can check with BE@A and Dante's on here for all your parts. Good Luck! Ronnie
Re: 1970 Roadrunner
[Re: Haase27Man]
#889732
12/28/10 01:47 PM
12/28/10 01:47 PM
Posts: 600 Vicksburg, MI
coffeeman383
Vicksburg, MI
A real air grabber 4-speed in red sounds pretty cool. N96 and D21 on the tag if it exists; these easily offset the missing 383. The hoods also rust on RR's at the hinges and the front and can be difficult to repair. Look for all the small air grabber parts too like switch, vacuum cannister, etc. The fiberglass hood box is also expensive but all this can be found used or repo'd. Air cleaner and carb mounting pan is also unique for air grabbers.
