Small block guys compression question. #888822
12/26/10 08:02 PM
12/26/10 08:02 PM
Roseville MN
72swgnr Offline OP
72swgnr  Offline OP
Roseville MN
For you guys that run small blocks and IRON heads.
Do you think 10.65-1 compression with closed chambered iron heads and a 251/257 duration cam and .038 quench will run on pump premium without detonation?
What have you gotten away with build wise running pump premium?
Re: Small block guys compression question. [Re: 72swgnr] #888823
12/26/10 08:04 PM
12/26/10 08:04 PM
SoCal
Brian Hafliger Offline
SoCal
If your at least 1000ft above sea level and don't see summer heat over 100° I think you'll be fine. You could always slow down the advance curve some if needed.
Brian
Brian Hafliger
Re: Small block guys compression question. [Re: 72swgnr] #888824
12/26/10 08:08 PM
12/26/10 08:08 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
if the gas ur using is truly 93 octane should be fine,i dont trust the gas stations near me
Re: Small block guys compression question. [Re: fishy340] #888825
12/26/10 09:07 PM
12/26/10 09:07 PM
Roseville MN
72swgnr Offline OP
72swgnr  Offline OP
Roseville MN
Thanks guys. I will mix in some race gas when it goes on the dyno and to the track.
Re: Small block guys compression question. [Re: 72swgnr] #888826
12/26/10 09:29 PM
12/26/10 09:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If on the dyno it says more timing try it with less
octane fuel... I have seen MOST of us are WAY to safe
on octane but always start with more than is needed
Re: Small block guys compression question. [Re: 72swgnr] #888827
12/27/10 12:00 AM
12/27/10 12:00 AM
Az
Crizila Offline
Crizila  Offline
Az
Tried that with Hyper pistons and under 10:1 and broke an upper ring land. Duration in the 248 range.
Fastest 300
Re: Small block guys compression question. [Re: 72swgnr] #888828
12/27/10 01:48 AM
12/27/10 01:48 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
What iron heads are you using that have a closed chamber?
RT
Re: Small block guys compression question. [Re: RTSrunner] #888829
12/27/10 03:15 AM
12/27/10 03:15 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I'm at 11.2cr with a 360 and J's at 59cc, 205 cranking psi, i run 93 all the time but you got to do your homework!!
Re: Small block guys compression question. [Re: RTSrunner] #888830
12/27/10 10:04 AM
12/27/10 10:04 AM
Roseville MN
72swgnr Offline OP
72swgnr  Offline OP
Roseville MN
RT
62cc RHS heads prepped by Brian@IMM
