Anyone tested the PROCOMP Aluminum heads? Or heard-
#88783
07/14/08 11:03 PM
07/14/08 11:03 PM
Posts: 475 HEMPSTEAD TX
CUUDAK
HEMPSTEAD TX
anything on them?? Seen them one ebay for $1099.00. Shows 285 cfm @ .500 lift?? ebay.com Item number: 220255527442
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Re: Anyone tested the PROCOMP Aluminum heads? Or heard-
[Re: earlybee]
#88785
07/15/08 01:08 AM
07/15/08 01:08 AM
CUUDAK
HEMPSTEAD TX
I have a Fresh set of 1967 915 heads with ferra 2.14int. and 1.88exh.
I was told that the bigger exhaust valve screwed the torque numbers?? Anyone tell me if this is true! Said that it would loss all torque thru curve??????????
[Re: CUUDAK]
#88786
07/15/08 01:49 AM
07/15/08 01:49 AM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
I'll never understand peoples addiction to Ebarf! Why not look at 440 Source Stealth heads that flow comparable numbers OOTB...for $899? AND come with someone behind them that WON'T tell you what a peice of YOU are IF there's problem...
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
[Re: CUUDAK]
#88787
07/15/08 08:07 AM
07/15/08 08:07 AM
Posts: 4,799 ILL
MLR426
ILL
915 heads with 2.14...lowering torque... Your question depends on alot of varibles. porting, cam, compression, intake, gear ?
logan426
