Re: 9.25 problems and their fixes,
[Re: AINTNRT]
#886971
12/24/10 01:54 PM
12/24/10 01:54 PM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
Mine went bad at 99K, a component part inside the Dana supplied trac loc broke and sent all kinds of metal everywhere. I was able to get it home..slowly.. I believe the problem was resolved by 03 models, and the other issue that I heard of is the front bearing going bad.. Probably change the gear lube and call it a day.. there are issues with just about any manufacturers products..Like Fords spitting out spark plugs..etc..
[Re: AINTNRT]
#886972
12/24/10 01:56 PM
12/24/10 01:56 PM
Posts: 36,840 South San Francisco, Californi...
MidPenMopar
Looking for fun? Keep looking
If you're that worried about it then I'd just put new clips in after you buy it for that extra piece of mind. The clips are cheap, under 20.00 I think, or install new clutches and clips. The later anti-spins, which is what the '03 has, were better then the earlier ones. IMO
Thank you for the great advice!!
Stu
