Hemi rocker arm pad radius? #886536
12/23/10 02:17 PM
12/23/10 02:17 PM
New York
polyspheric Offline OP
New York
The plain (pallet) original rockers, not roller.
Does anyone know what the actual dimension is, and are there more than 1?
Shepard's book has nothing, I checked.
Any large blueprint drawings or diagrams I can translate from?
Thanks.
Boffin Emeritus
Re: Hemi rocker arm pad radius? [Re: polyspheric] #886537
12/23/10 07:21 PM
12/23/10 07:21 PM
Indiana
maxie Offline
maxie  Offline
Indiana
I have an old set in the garage I could check with a radius gage.
Re: Hemi rocker arm pad radius? [Re: maxie] #886538
12/23/10 07:59 PM
12/23/10 07:59 PM
New York
New York
Excellent, thanks!
1 intake and 1 exhaust should do it - I suspect they're different (even with the same lift) because the exhaust arms are so much looonger.
Boffin Emeritus
Re: Hemi rocker arm pad radius? [Re: polyspheric] #886539
12/23/10 08:05 PM
12/23/10 08:05 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
It makes sence that the longer rockers would have a flatter pad vs the shorter rocker. What are you checkin for, just curious.
Kasey
Re: Hemi rocker arm pad radius? [Re: polyspheric] #886540
12/23/10 08:10 PM
12/23/10 08:10 PM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
For the intake valve I know the following:
If you want it perfect, it depends on the lift. I had to grind mine with a smaller radius on the outer part of the tip to stay in appx center contact with the valve. (it was for a Crane R290 roller .7" valve-lift) I do not know the radius, though, but I would say it shifts towards the outer edge.
Thanks,
my
