Belt Weatherstrips....how to attach
#886486
12/23/10 01:49 PM
12/23/10 01:49 PM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
I have to replace the "fuzzies" on the steel upper inner quarter trims panels on my '68 GTX. I notice that Ma Mopar stapled these in place. What's everyone doing when they replace them? Rivets? Screws? There are no holes in the new strips.
Re: Belt Weatherstrips....how to attach
[Re: Paul Jacobs]
#886488
12/23/10 09:18 PM
12/23/10 09:18 PM
Posts: 587 IL . usa
cjs69mope
IL . usa
I have heard people using both rivets and screws but i found that when you do that the pannel does not slip over and down flush on the body lip because the screws or rivets will hit . What i did was got some very heavy roofing staples and took my time clamping the fussy in place with small welding pliers and small electric drilled the holes for the staples and crimped them as tight as possible like the factory did using another set of pliers . Worked perfectly , just like the factory i even found that if you stagger the staples the it holds them tighter . Cj
1969 Dodge Charger
1969 Dodge Superbee
[Re: superwrench]
#886493
01/03/11 07:49 PM
01/03/11 07:49 PM
Posts: 366 San Gabriel, CA 91775
rexus31
I riveted mine in place. No issues at all.
2007 Dodge Charger R/T, Road and Track Performance Group, Steel Blue
1965 Chrysler 300 Convertible, 383 4V, 727TF, Factory Air, Spanish Red
1964 Pontiac GTO, Tri-Power, 4 Speed, Grenadier Red
"What ain't no country I ever heard of. They speak English in What?" - Jules Winnfield
