old school 292/509 Cam what performance did u get.?
#886280
12/23/10 12:03 PM
12/23/10 12:03 PM
Posts: 768 Maryville tn
67coronetman
Maryville tn
Look i know we all have our likes & dislikes that's ok ** But mopar made a great cam in the 292/509 its a great street cam and with the right heads headers & so on i have seen B-Bodies run mid 11 and still drive around town with full interior so lets hear what you have.! So that is what i am planning on doing to my 1966 plymouth satellite. I have all the right things to make this car scream.! it now has a solid cam from comp i hate it.! ** SO TELL ME YOUR COMBOS WITH THIS 292/509 CAM IN A 440 MOTOR AND HOW IT RUN AT ITS BEST TIMES.! Here is a video of my car.! http://www.youtube.com/watch?v=iLMuETuCen4
Old car are me......
Re: I know its old school but it works well.! 292/509 cam
[Re: 67coronetman]
#886281
12/23/10 12:16 PM
12/23/10 12:16 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
easy enough, although low low 12's are probably more like. 10:1 440, ported iron or Alum heads, RPM intake 850DP, Headers, good ingnition system, 3800 stall, good shifting trans and 4.10's should get you really close to 11's and still decent on the street. Advancing the cam can help get you some bottom end as well. Of course better heads, more compression, expensive convert, will help even more.
oh and I had a .030 over 383 11:1, ported 915 heads, 509 cam (straight up), Torker II 750DP, 1 7/8 headers, MSD, 3800 stall 4.56's in a 68 Dart ran 11.86 w/ a very bad trans.
[Re: buildanother]
#886283
12/23/10 12:21 PM
12/23/10 12:21 PM
67coronetman
Maryville tn
I agree totally i am going to run the boss hog 3200-3600 stall i have with 3:91 gears that are already in the car.! I already have heads Indy Sr so flow will be no problem.!
[Re: 71 Charger R/T]
#886285
12/23/10 12:40 PM
12/23/10 12:40 PM
67coronetman
Maryville tn
I am lucky i don't have power brakes so i am good.! I have a friend that had this combo in a B-Body and his best time was 11:68 on street tires.
#886286
12/23/10 12:44 PM
12/23/10 12:44 PM
67coronetman
Maryville tn
Oh yes mine is still 10.5 compression.!
[Re: 67coronetman]
#886287
12/23/10 12:49 PM
12/23/10 12:49 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
girl down in Shreveport has a nice orange RR w air grabber hood, 440 six pack with the 509 in it, she was running mid 11s on slicks with it.
not sure the rest of the build though...compression, etc. but it was a stock stroke 440, 6pack motor.
**Photobucket sucks**
[Re: 70Cuda383]
#886290
12/23/10 01:15 PM
12/23/10 01:15 PM
Posts: 398 Texas
70Runnerdude
Texas
My 68 Roadrunner had a 440 with 10 to 1 pistons 906 heads with 4 speed and a RPM intake with a Demon Carb and headers. It ran awesome , I loved that set up !!!!!!!!!!! Only problem I had was I wiped out a lobe on it . I would build another just like it and plan on doing just that in a year or so . Dave
[Re: Paul_Fancsali]
#886291
12/23/10 01:17 PM
12/23/10 01:17 PM
Posts: 4,785 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Why do you hate the Comp Cam solid lifter set up thats in there currently?
Keep old mopars alive.
[Re: Paul_Fancsali]
#886292
12/23/10 01:24 PM
12/23/10 01:24 PM
67coronetman
Maryville tn
Yea i alway advance my cams for the low end torque.! thanks>!
[Re: 5spdcuda]
#886293
12/23/10 01:25 PM
12/23/10 01:25 PM
67coronetman
Maryville tn
Sweet i look into that have a great day.!
[Re: Paul_Fancsali]
#886294
12/23/10 01:48 PM
12/23/10 01:48 PM
67coronetman
Maryville tn
I got one for you guys.! ?? i have a general kinetics cam i have one for a big block with almost the same profile as a 292/509 cam.!
[Re: Paul_Fancsali]
#886295
12/23/10 02:46 PM
12/23/10 02:46 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Advance it 2-4 degree's makes a better idle and better low end
Yes install it at 103 and this cam really responds well (104 to 102)
[Re: 2boltmain]
#886296
12/23/10 03:49 PM
12/23/10 03:49 PM
67coronetman
Maryville tn
Way to much noise for me and i really don't think the streetablity is as good.! But that is what i think and like others may think different.!
[Re: 383man]
#886298
12/23/10 10:13 PM
12/23/10 10:13 PM
67coronetman
Maryville tn
That's what i am saying i have a solid lift comp cam now i just don't like a solid cam they make more noise than i like. plus my years of racing cars and street cars i just like a hydraulic cam better it seem to be more street friendly.!
[Re: 5spdcuda]
#886299
12/23/10 10:18 PM
12/23/10 10:18 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Back in the late 70,s Direct Connection did a back to back test with a bracket car between the SSH-44 and the MP 509. The results were SSH-44 1.621 60ft. 11.95, 1/4 @ 115.18 MP 509 1.621 60ft. 11.82, 1/4 @ 116.61 I agree with you that the following MP cams were copies of the designs that Racer brown came up with. If my specs are correct the SSH-44 actually had less duration then the MP 509. Witch, would indeed make it a better street cam then the 509. As far as the 509 goes, it can be a screamer with the right combo, as well as some of the other MP grinds. mike
