318 timing sprocket marks
#886209
12/23/10 11:11 AM
12/23/10 11:11 AM
Posts: 869 Sugarloaf, PA. USA
JamiePasson
Sugarloaf, PA. USA
I am having trouble with the farm truck. 1978 Dodge Power Wagon. 318. Took the timing cover off because we suspected that it jumped a tooth on the chain. Well, it didn,t but the chain is stretched BAD. So, I am changing it. I got a Mopar Perf (Melling) double roller timing chain. However, this is where I am confused. Correct me if I am wrong: You are supposed to put the engine on TDC and then line the sprocket marks up when installing the chain. Crank mark at 12:00, cam mark at 6:00. When the crank is at TDC, the keyway on the crank is at 2:00. When I removed the old timing chain and sprockets, you can plainly see the dimple is at 12:00 on the crank sprocket and the keyway is at 2:00. On the new sprocket, you have three options for timing. 0 degrees, 4 degrees advanced or 4 degrees retarded. I obviously want to use the 0 degree keyway on the crank. The problem is that there is only one dimple (timing mark) on the crank sprocket that is right above the 0 degree keyway. Where I am confused is that this is going to require me to turn the crank way back to line the timing marks up on the two sprockets. IT will no longer be on TDC. Any ideas? Miss stamped sprockets? Am I missing something? Thanks, Jamie ![](/ubbthreads/images/graemlins/smilie_help.gif)
Re: 318 timing sprocket marks
[Re: buildanother]
#886215
12/23/10 01:49 PM
12/23/10 01:49 PM
Posts: 606 Montana
Yancy Derringer
Montana
I would install the sprockets "on the marks" and then when you reinstall the timing cover and balancer, CHECK TDC. Use a positive stop: ![](http://www.jerrybramlett.net/images/pic_installation.jpg) Put in no1, making sure the engine is NOT on TDC, and there is room for the tool to go in. Gently wrench the engine around until it stops "on the stop" and make a temporary mark on the wheel right under TDC on the tab Do the same CCW True TDC will now be halfway between these two temporary marks, and if the original mark was correct, that is where it will be You may just be seeing the difference caused by chain stretch As someone else said, when the marks are "dot to dot" the engine is ACTUALLY on "no6 ready to fire", not no1. If you do not rotate the engine you want the rotor pointing to 6, not 1. You probably did not pull the dist, so it should be OK except a minor movement to retime (for chain stretch)
[Re: jsswope67]
#886219
05/09/12 03:26 PM
05/09/12 03:26 PM
Posts: 75,098 A Banana Republic near you.
JohnRR
My local parts store does not have a positive stop...
Is this thread still open and being read? So should I point my rotor to #6?? I set my marks the same as in the picture above. 12 o clock and 6 o clock, never found out this info until now.
2 years after it was originally opened , doubtful .
But yes when the dots are aligned as in the picture above that is actually firing cylinder #6 , #1 cylinder is at TDC , but on a different part of the stroke cycle.
[Re: 70AARcuda]
#886224
05/09/12 04:30 PM
05/09/12 04:30 PM
Posts: 27 PA
jsswope67
PA
[Re: jsswope67]
#886225
05/09/12 05:19 PM
05/09/12 05:19 PM
JohnRR
It starts and idles fine, so leave it that way or change the dist wire for #1 to #6?
Revs ok, idles with some slight hissing and small pops, has some blowback out of the EGR hose.
Runs awhile then heats up and pings, just put new thermostat in it and have the heater core out.
I did reset the timing some and it heats up sooner than it did, about 1 mile vs. 8miles.
Pings, loses power and heats up. Plugs are very soot filled each time.
Also cannot see my mark with the timing light, solid line across dampener painted white.
Well first off it's running so you must have done something right, if the distributor was off 180* the car would not even start.
But that said there is no guarantee that the timing gears are marked correctly , more than once someone has gotten an incorrectly indexed set.
[Re: rth]
#886227
05/09/12 07:05 PM
05/09/12 07:05 PM
Posts: 4,848 Memphis
HemiRick
Memphis
Nope both small block and big line up dot to dot and are firing on number 6 when doing so.
If the engine is running at this point no need to do anything. You got lucky.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#886228
05/09/12 09:56 PM
05/09/12 09:56 PM
Posts: 27 PA
jsswope67
PA
Other than the heating up issue, loss of power and pinging of valves after a while its fine, I read on another board of a similar issue, they tought it was running too too lean, person swapped out a carb and it fixed it, at this point, I do not want to go chasing my tail, so may play with needle adjustments, rebuilt the carb three times to make sure, put in another step up piston assembly with needles from another carb that may have had good settings, so not sure where to go. I know one thing if I have to pull the timing cover off again (for the third time) I will put in a rougher cam. Current carb is a Carter BDD 2 barrel. ![](/ubbthreads/images/graemlins/2491406-danstruck.gif)
