I have one of their 70 Cuda pads, currently unmounted to the dash, although test fitted to the dash frame, fit very nicely, a few mounting holes were off but nothing major, needs a little trimming to fit the upper/under dash light panel properly, but the grain, finish, and lines are very nice, the emblem is correct in appearance, but the 71-4 would be different, overall it's a pretty piece,..... I also have a Ultimate Rides 70 Cuda pad on my other car, again a nice piece, grains a little different than factory, but very close,....the UR pad is a little more $$$, and needed to be "coaxed" onto the frame.....but if I needed another pad, I'd go with the SD pads
Note....there is a core charge, shipping on the core was $65
