1966 Chevy II – Twin Turbo Nova
Race or Show - NMCA / Outlaw 10.5
Has been 6.76 @ 216 - NMCA legal trim @ 3175 lbs – extremely consistent
Watch the video @
http://www.youtube.com/watch?v=gzi9OXuMMLU Chassis Engineering built - SFI 25.2 certification
Extremely detailed, everything painted, anodized, chromed or powder coated
550ci Big Block Chevy, built by Ty-Tech Performance
New Twin Precision Pro Mod 88 Turbo’s
Precision PT4000 rear mounted
intercooler
Large ice tank and recirculating pump, transmission cooler
Donovan 9.8 aluminum block, extra head studs, roller thrust bearing
Dart 18 degree Big Chief heads
Wilson Sheet Metal intake with 220lb Precision injectors & D fuel rails
SCP 4 stage dry sump with Kinsler Pump
Johnson HTP - 2 stage vacuum pump
T&D / Jesel valve train
Tial 60mm Waste gates, Procharger blow off
Bruno Converter Drive, 1.25” large mirage shaft
Lenco CS2 / 3 speed with pods & ACD air shift
Neal Chance bolt together converter
Jerry Bickel 9.5” floater housing, MW 40 spline spool
Strange axles and Strange Dual caliper brakes
16 x 16 Weld bead locks with MT 33/10.5-16 will fit 34.5/17-16
Front Weld spindle mount with Strange Struts and brakes
All Bickel suspension underneath, including JBRC chrome wheelie bars
Santhuff billet double adjustable rear shocks - new
Twin Stroud Air Launchers
Big Stuff 3, AMS 1000 boost controller and MSD 7 with fresh tune by Don Bailey
Racepak V300 with every imaginable sensor and digital dash
Professionally wired by Wires & Pliers
Firefox 10lb system with multiple heads and dual activators
C02 system for Bruno, AMS and chutes
Braille Lithium 16 volt – the 7lb battery
Have original painted steel doors with vent and glass roll down windows
Pro-Jack
Spare converter and misc parts
This is a real Nova SS with VIN and FL title
If I didn’t mention something, it has the best of what it needs.
No tire kickers - There will be absolutely NO disappointments with this car in looks or performance
POMPANO BEACH, FL
130,000 US dollar.
