engine builders need block advise
#885394
12/22/10 01:45 AM
12/22/10 01:45 AM
Posts: 3,518 pacific northwest
Stroker Scamp
pacific northwest
ok after reading the recent post on sonic numbers im starting to get freaked out, is my motor a ticking timebomb? see attached
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
Re: engine builders need block advise
[Re: Stroker Scamp]
#885396
12/22/10 02:02 AM
12/22/10 02:02 AM
Posts: 19,400 Las Vegas
Al_Alguire
Las Vegas
The major thrust numbers on not horrible. In fact I would say they are fairly typical of many of the stock block race Mopars out there.
[Re: JohnRR]
#885397
12/22/10 02:03 AM
12/22/10 02:03 AM
Stroker Scamp
pacific northwest
already built and been running, its 1/2 filled if that makes any difference, the other post had way thicker numbers and was talk about the block being junk, HP is high fives according to the ets/weight calcs
[Re: Stroker Scamp]
#885400
12/22/10 02:13 AM
12/22/10 02:13 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Was that the finished bores or was it still waiting to be bored... I see it said 4.030 and then it was sonic checked... usually you sonic check it to find out if it can be bored ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Stroker Scamp]
#885402
12/22/10 02:19 AM
12/22/10 02:19 AM
Triple Threat
Renton Washington
All the thrust sides of the bore are decent enough considering its already bored to size. Sides of the bore (front and back as the engine sits in the car) don't take nearly as much abuse so you can get away with less.
Its together, run it!
[Re: @#$%&*!]
#885404
12/22/10 04:34 PM
12/22/10 04:34 PM
Remember a sleeve is just .125 thick and when put back in a damaged bore thats all you have--installed right they work so....... I have never seen a stock block that was not thin somewhere--run it don't worry IMO
[Re: ]
#885405
12/22/10 05:14 PM
12/22/10 05:14 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
IMO you're getting close, but you have a 1/2 fill. Just as important as minimums thickness is where that thickness is. A good sonic test should record numbers around an inch apart up each surface, plus the minimum thickness. You've got a 1/2 fill. If the minimum is above the fill but still near the center of the stroke you may only have lost power from wall deflection. If it's below the fill line you're fine. I use .150 as minimum for my engines but I dont hit your power range typically. If this was just going together I'd say get another block for near 600hp. You should be abel to see how good things stay by doing leakdowns periodically. If you see a trend of greater leakage, figure the bores may be flexing and look for the signs of friction or lost ring seal.
