Page 3 of 3 1 2 3
Re: Help me decide how to build this race project [Re: MR_P_BODY] #883420
12/19/10 07:21 AM
12/19/10 07:21 AM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
I can't catch the S-10
Its a SBC 434 with a 300 shot
Runs 5.80's
But, I hate going to the track by myself so I only like to go when someone else is there
Ask him to turn the bottle off then you guys can run...
I myself am building to go 10.2 - 10.3 and drive it
on the road... whats the weight on that... I use to
have one back when I was in school(was a /6 but I
put a 273 in it) but I dont recall the weight... I
want to say 3000
Go small block turbo,all he will see is your
tail lights
Re: Help me decide how to build this race project [Re: B1KILLER] #883421
12/19/10 08:19 AM
12/19/10 08:19 AM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
Australian ap6 wagon. Tunnel ram 360 with 4 speed.
Re: Help me decide how to build this race project [Re: 572B1] #883422
12/19/10 08:44 AM
12/19/10 08:44 AM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
here's another shot.
Re: Help me decide how to build this race project [Re: 572B1] #883423
12/19/10 10:40 AM
12/19/10 10:40 AM
gregsdart Offline
gregsdart  Offline
For a 11.50 and up ride, I would go with frame connectors, ladder bars to make full use of stock wheel wells. Will have to set the rear axle back about 3/4 inch.
Front would get a home made rack and pinion, coil over/spring combo with pass side shock tower layed over to fit TTI 67 up bb a body under chassis headers. I don't know if going with the rack and dumping the torsion bars give enough room for the headers, but plan to find out in the future. Those two moves open up a ton of space combined with a little shock tower surgery. The plan would be minimal shock tower move to keep the stock appearance theme as much as possible. Motor would be a 512 BB low deck, Indy dual plane with a juice cam and eddy heads. If you go conservative on the cam, it should stay in the mid elevens and idle like a kitten. Want more? Roll bar, head porting , looser converter and a big flat tappet and you are running 10.s Want 9.s? dump the dual plane for an x type intake, cage /dominater/roller.
Another route would be a hotter motor, no roll bar but a throttle stop to keep you at 11.50, but a mean mph!
Re: Help me decide how to build this race project [Re: gregsdart] #883424
12/19/10 11:06 AM
12/19/10 11:06 AM
ky
headhunter Offline
headhunter  Offline
ky
Bigdad from what i have seen of your rides i know the real sleeper deal is out you will make it slick as heck. i personaly leave it looking as close as it does now the look on everyones face when you run it is priceless i would go with a small block block with a single 76 mm turbo with a 518 trans with a brake you can be creative in hideing a cage if its needed you can always make it look good when the sleeper thing gets old it would look good silver with red insides
Re: Help me decide how to build this race project [Re: gregsdart] #883425
12/19/10 11:08 AM
12/19/10 11:08 AM
Richmond , Virginia
BEEQUIK Offline
BEEQUIK  Offline
Richmond , Virginia
There used to be one of those at Lebanon Valley that raced in super pro. Guy had a big hemi in it and he sat in the backseat! Man it was ugly,but it was FAST!! Let me see if I can dig up a pic of that thing.It was in a magazine a while back,some sort of famous racecar or something... Blue and Silver
Re: Help me decide how to build this race project [Re: 572B1] #883426
12/19/10 12:20 PM
12/19/10 12:20 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
That picture made me smile
Re: Help me decide how to build this race project [Re: bigdad] #883427
12/19/10 07:18 PM
12/19/10 07:18 PM
Finland
mafo Offline
mafo  Offline
Finland
maybe a new hemi with turbo and a 518 trans, I guess the motor could be close to stock and still make a LOT of power, but I don t know anything about these motors, just what I ve seen here... and I really like your car
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: Help me decide how to build this race project [Re: mafo] #883428
12/19/10 09:20 PM
12/19/10 09:20 PM
Whatever you do, don't paint it.....SILVER!
Re: Help me decide how to build this race project #883429
12/21/10 02:42 AM
12/21/10 02:42 AM
MD
Kevins493 Offline
Kevins493  Offline
MD
Car is owned by a friend. Runs 11.20's.
Re: Help me decide how to build this race project [Re: bigdad] #883430
12/21/10 12:56 PM
12/21/10 12:56 PM
Oregon,USA
RAT PATROL Offline
RAT PATROL  Offline
Oregon,USA
What the........Who took the........You don't need advice on the grocery getter. You need to do something about the crime problem in your neighborhood first. Someone has stolen all the trees. Git y'all a trailer and git up here to Oregone and we'll git ya some trees to take home. We're given em all away to China and Japan, so you Texicans may as well git you some.
Re: Help me decide how to build this race project [Re: RAT PATROL] #883431
12/21/10 04:36 PM
12/21/10 04:36 PM
Netherlands
72Challenger Offline
Netherlands
Keep it the sleaper look for stealth mode. Put in a moderate stroker smallblock making it run high 10's / low 11's.
Just make sure you install a towbar to bring you real racecar to the track
Page 3 of 3 1 2 3
