Re: Guys with no inner fenders on stock type a-bodies?
[Re: bigtimeauto]
#883102
12/19/10 09:40 AM
12/19/10 09:40 AM
Posts: 803 Idabel,Oklahoma
Gary Robbins
Idabel,Oklahoma
you need to build the front so everything ties together using the engine plate and transmission midplates as crossmembers:
![](http://gallery.bigtimeauto.com/albums/1969-Dart/misc_065.jpg)
Thanks everyone for the replies..it was what i was looking for.We have off the shelf tti headers and have you ever checked/changed spark plugs with everything hot...almost impossible.We run our car conservative and looking to step it up and will have to keep a check on the tune closer...rarely check them now lol.Your options on custom headers is alot better with no inner fenders and i was concerned about the upper control arm mount...
Bob thats exactly what i kneeded as i have a alterkation frontend also...i like the clean look...Thanks again everyone...Gary
[Re: rebel]
#883103
12/19/10 10:28 AM
12/19/10 10:28 AM
Posts: 16,932 NC
440Jim
NC
i decided the shock mount was interfearring with making some decent flowing headers so we moved the shock mount to the bar & cut the rest out.
Yea, if you have the factory steering box and torsion bars, those shock towers make the initial bend for the center cylinders tight, especially for bigger headers over 2". I believe they will flow better with a straighter shot off the head.
[Re: MR_P_BODY]
#883106
12/19/10 12:46 PM
12/19/10 12:46 PM
Posts: 6,840 The Swamp
Sixpak
The Swamp
Just an fyi - those inner fenders do a lot to strengthen the uni-body. And they will weigh much less than the cage bars you would need to install to regain that strength...you also lose a good many of the places that bolts go into the fenders to hold them in place.
On the weight... I disagree with you... thats alot of metal your taking out... but I use moly tubing which is 1.36# per foot but if you use MS its 2.0#
When I did this using mild steel 1 3/4 .134 wall the tubing definitely weighed more than the inner fenders. All total the inner fenders were about 20 pounds.
[Re: cudadon]
#883107
12/19/10 01:22 PM
12/19/10 01:22 PM
Posts: 1,141 Phoenix,Az.
hemicop
Phoenix,Az.
If ity were me, I'd do what the old P/S cars did. They simply ran a piece of sheetmetal from the framerail to the fender with the edge bent-over so as to bolt the piece to the fender. Since they used coilovers, they simply notched the sheetmetal to accomodate the upper mount. This provided them with extra room (since there were no contours) yet kept air from getting caught in the engine bay as you're concerned with.If you look at many of the early 70s P/S mopars (Motown MIssile, Herb McCandless's Demon, etc.)they were done this way. Since these were factory cars, obviously someone, somewhere did the research to find & figure out it was necessary to isolate the engine bayand since you ARE talking speeds similiar to early P/S type cars, this fix seems applicable
[Re: dennismopar73]
#883111
12/19/10 02:10 PM
12/19/10 02:10 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
BloFish, can i have your car?
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: rebel]
#883112
12/19/10 02:26 PM
12/19/10 02:26 PM
Posts: 1,417 MS
redex79
MS
CAP upper arms, Aerospace hubs,rotors.calipers. Brace is to the firewall.
Truckin Weekend ! 70 Dodge Dart Swinger 11 Ram 1500 Laramie 4x4 21 Dodge Durango GT
[Re: redex79]
#883113
12/19/10 02:57 PM
12/19/10 02:57 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
Our local heads up classes require inner fenders. I think it would be nice to have some aluminum inner fenders that were dzus'd on, I believe that's what BondoBob just had done to his DartSport.
[Re: cudadon]
#883115
12/19/10 04:06 PM
12/19/10 04:06 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
Do you all think that with NO inner fenders it lets a lot more air in going down the track? ...
I think the air comes in from the front and taking out the inner fenders lets it exit at the sides, which may not be the best at speed but it should reduce under hood pressure. I like to go to the top-end and watch the plastic cars come by. Some take on very funny shapes at speed. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: dennismopar73]
#883116
12/19/10 04:14 PM
12/19/10 04:14 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
wish i could download pics of mine just cant seam to find out how
2 Options,
A) go to the archives and read the post I did on resizing and posting pics
B) I can PM you my number and walk you through it.
[Re: WILD BILL]
#883120
12/19/10 07:48 PM
12/19/10 07:48 PM
Posts: 2,177 ill
dennismopar73
ill
well may have to do that i reposted my new car pics but they didnt attatch so i dunno me dumb ![](/ubbthreads/images/graemlins/alien.gif) thanks bill try to trdo the pics again later and repost what my inners look like ![](/ubbthreads/images/graemlins/eeek.gif) not any diff than what im seeing tho after all only so many ways to do them ![](/ubbthreads/images/graemlins/popcrn.gif) thank you ![](/ubbthreads/images/graemlins/santananer.gif)
[Re: dennismopar73]
#883121
12/19/10 09:02 PM
12/19/10 09:02 PM
Posts: 1,030 ohio
67mprfan
ohio
here mine 71 demon removable front clip
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
