Page 2 of 3 1 2 3
Re: Guys with no inner fenders on stock type a-bodies? [Re: bigtimeauto] #883102
12/19/10 09:40 AM
12/19/10 09:40 AM
Idabel,Oklahoma
Gary Robbins Offline OP
Idabel,Oklahoma
you need to build the front so everything ties together using the engine plate and transmission midplates as crossmembers:
Thanks everyone for the replies..it was what i was looking for.We have off the shelf tti headers and have you ever checked/changed spark plugs with everything hot...almost impossible.We run our car conservative and looking to step it up and will have to keep a check on the tune closer...rarely check them now lol.Your options on custom headers is alot better with no inner fenders and i was concerned about the upper control arm mount...
Bob thats exactly what i kneeded as i have a alterkation frontend also...i like the clean look...Thanks again everyone...Gary
Re: Guys with no inner fenders on stock type a-bodies? [Re: rebel] #883103
12/19/10 10:28 AM
12/19/10 10:28 AM
NC
440Jim Offline
440Jim  Offline
NC
i decided the shock mount was interfearring with making some decent flowing headers so we moved the shock mount to the bar & cut the rest out.
Yea, if you have the factory steering box and torsion bars, those shock towers make the initial bend for the center cylinders tight, especially for bigger headers over 2". I believe they will flow better with a straighter shot off the head.
Re: Guys with no inner fenders on stock type a-bodies? [Re: WILD BILL] #883104
12/19/10 11:08 AM
12/19/10 11:08 AM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Do you all think that with NO inner fenders it lets a lot more air in going down the track? More aero drag? My hood lifts up at about 138 or so, I wondered if it would be less air if I had inners? What do you think? Don
Re: Guys with no inner fenders on stock type a-bodies? [Re: cudadon] #883105
12/19/10 11:29 AM
12/19/10 11:29 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I would think it lets more air in under the hood.
However, In your case I would suggest maybe adding more hood pins.
Can't really tell by the pic you posted but it looks like you may only be using 1 in each corner.
I have 10 Dusz fasteners on mine and it's nice a satble.
Re: Guys with no inner fenders on stock type a-bodies? [Re: MR_P_BODY] #883106
12/19/10 12:46 PM
12/19/10 12:46 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Just an fyi - those inner fenders do a lot to strengthen the uni-body. And they will weigh much less than the cage bars you would need to install to regain that strength...you also lose a good many of the places that bolts go into the fenders to hold them in place.
On the weight... I disagree with you... thats alot
of metal your taking out... but I use moly tubing
which is 1.36# per foot but if you use MS its 2.0#
When I did this using mild steel 1 3/4 .134 wall the tubing definitely weighed more than the inner fenders. All total the inner fenders were about 20 pounds.
Re: Guys with no inner fenders on stock type a-bodies? [Re: cudadon] #883107
12/19/10 01:22 PM
12/19/10 01:22 PM
Phoenix,Az.
hemicop Offline
hemicop  Offline
Phoenix,Az.
If ity were me, I'd do what the old P/S cars did. They simply ran a piece of sheetmetal from the framerail to the fender with the edge bent-over so as to bolt the piece to the fender. Since they used coilovers, they simply notched the sheetmetal to accomodate the upper mount. This provided them with extra room (since there were no contours) yet kept air from getting caught in the engine bay as you're concerned with.If you look at many of the early 70s P/S mopars (Motown MIssile, Herb McCandless's Demon, etc.)they were done this way. Since these were factory cars, obviously someone, somewhere did the research to find & figure out it was necessary to isolate the engine bayand since you ARE talking speeds similiar to early P/S type cars, this fix seems applicable
Re: Guys with no inner fenders on stock type a-bodies? [Re: Sixpak] #883108
12/19/10 01:35 PM
12/19/10 01:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Your tubing weighs 2.31 lbs per foot and I would guess
you used about 7'
Re: Guys with no inner fenders on stock type a-bodies? [Re: MR_P_BODY] #883109
12/19/10 01:43 PM
12/19/10 01:43 PM
On the run…
BloFish Online penguin-006
BloFish  Online Penguin-006
On the run…
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Guys with no inner fenders on stock type a-bodies? [Re: BloFish] #883110
12/19/10 02:04 PM
12/19/10 02:04 PM
ill
dennismopar73 Offline
ill
wish i could download pics of mine
just cant seam to find out how
Re: Guys with no inner fenders on stock type a-bodies? [Re: dennismopar73] #883111
12/19/10 02:10 PM
12/19/10 02:10 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
BloFish, can i have your car?
Re: Guys with no inner fenders on stock type a-bodies? [Re: rebel] #883112
12/19/10 02:26 PM
12/19/10 02:26 PM
MS
redex79 Offline
redex79  Offline
MS
CAP upper arms, Aerospace hubs,rotors.calipers. Brace is to the firewall.
Truckin Weekend !
70 Dodge Dart Swinger
11 Ram 1500 Laramie 4x4
21 Dodge Durango GT
Re: Guys with no inner fenders on stock type a-bodies? [Re: redex79] #883113
12/19/10 02:57 PM
12/19/10 02:57 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Our local heads up classes require inner fenders.
I think it would be nice to have some aluminum inner fenders that were dzus'd on, I believe that's what BondoBob just had done to his DartSport.
Re: Guys with no inner fenders on stock type a-bodies? [Re: ProSport] #883114
12/19/10 03:20 PM
12/19/10 03:20 PM
Super Scamp Offline
Super Scamp  Offline
No inners here. Just got the headrers out of powder coat and looking good. new pics soon when motor gets installed and the first of the year.
Just One Man's Opinion Mopar Mafia Racing
Re: Guys with no inner fenders on stock type a-bodies? [Re: cudadon] #883115
12/19/10 04:06 PM
12/19/10 04:06 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Do you all think that with NO inner fenders it lets a lot more air in going down the track? ...
I think the air comes in from the front and taking out the inner fenders lets it exit at the sides, which may not be the best at speed but it should reduce under hood pressure. I like to go to the top-end and watch the plastic cars come by. Some take on very funny shapes at speed.
Re: Guys with no inner fenders on stock type a-bodies? [Re: dennismopar73] #883116
12/19/10 04:14 PM
12/19/10 04:14 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
2 Options,
A) go to the archives and read the post I did on resizing and posting pics
B) I can PM you my number and walk you through it.
Re: Guys with no inner fenders on stock type a-bodies? [Re: hemicop] #883117
12/19/10 04:40 PM
12/19/10 04:40 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
here's an example of what most had back then thin .035 aluminum and Dzus fasteners
home of the
Sox and Martin Hemi Duster
Re: Guys with no inner fenders on stock type a-bodies? [Re: sixpackgut] #883118
12/19/10 04:42 PM
12/19/10 04:42 PM
On the run…
On the run…
For keeps?
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Guys with no inner fenders on stock type a-bodies? [Re: BloFish] #883119
12/19/10 07:00 PM
12/19/10 07:00 PM
Finland
mafo Offline
mafo  Offline
Finland
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: Guys with no inner fenders on stock type a-bodies? [Re: WILD BILL] #883120
12/19/10 07:48 PM
12/19/10 07:48 PM
ill
ill
well may have to do that
i reposted my new car pics but they didnt attatch
so i dunno me dumb
thanks bill try to trdo the pics again later
and repost what my inners look like
not any diff than what im seeing tho
after all only so many ways to do them
thank you
Re: Guys with no inner fenders on stock type a-bodies? [Re: dennismopar73] #883121
12/19/10 09:02 PM
12/19/10 09:02 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
here mine 71 demon removable front clip
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Page 2 of 3 1 2 3
