W5DART66 intake conversion pics
#882435
12/17/10 02:07 PM
12/17/10 02:07 PM
Posts: 2,584 sycamore,ohio
BobsProFab
sycamore,ohio
1 the adapter opened up
Re: W5DART66 intake conversion pics
[Re: BobsProFab]
#882444
12/17/10 07:18 PM
12/17/10 07:18 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Thought it was going in the Blue A-body you've been working on?
[Re: ProSport]
#882448
12/17/10 09:26 PM
12/17/10 09:26 PM
BobsProFab
sycamore,ohio
Probably just long enough to get a photo! You're worse than me Bondo.
i already got pics of it in the car so its time to broom it !
[Re: ProSport]
#882450
12/18/10 02:39 PM
12/18/10 02:39 PM
Posts: 3,505 DFW
mr_340
DFW
Did you open up the plenum area at the carb pad? Did you cut back the runner walls or machine around them and leaving them sticking into the plenum area? Is that better than tapering the Dominator flange down to the 4150 size?
Floyd Lippencott IV
[Re: mr_340]
#882451
12/18/10 02:49 PM
12/18/10 02:49 PM
BobsProFab
sycamore,ohio
the intake is un touched for now there is not enough meat on this intake to just do a 4500 conversion on. we disscussed welding a 4500 flange to the intake. this is a option i wanted Brett to take a look at before i start ![](/ubbthreads/images/graemlins/weld.gif) on it. this is just to test with on the dyno to compare it to my tunnel ram.
